Compaq Presario CQ60-220US PC Laptop Logo
Posted on Mar 14, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My notepad is switching on fine, but the screen is very faint (dark) i'm trying to find out whether its the backing bulb or the FL inverter. Need advice?
Creative Tech
Level 3:
  • Master 1,719 Answers
  • Posted on Mar 14, 2011
Creative Tech
Master
Level 3:
Answers
1719
Questions
Helped
635949
Points
5906
Hi Danny,
Either of the parts can be faulty or in some rare cases both. In most of such cases (HP-Compaq) that I received for repair, it was Invertor. Inspect the Invertor for any apparant physical damages (burnt coil or circuit components etc). Inverter can be checked by disconnecting the present CCFL and connecting a fresh/ working CCFL (Backlight) before actually removing the CCFL as it is difficult and unnecessary to take it out if its not the fault.
So, my advice is that you check the LCD display for replacement of Inverter . I have found a general link about CCFL replacement. Click here for detailed and graphical DIY instructions about LCD disassembly.
Make sure you take proper precaution while working inside LCD, as the inverter generates a very high voltage.
IF YOU ARE NOT EXPERIENCED WITH WORKING INSIDE SUCH ELECTRONIC COMPONENTS, I SUGGEST THAT YOU SEEK PROFESSIONAL ASSISTANCE FROM AUTHORISED SERVICE/ REPAIR CENTER FOR REPLACEMENT OF CCFL OR INVERTER.
Hope it helps! Good Luck!
CreativeTECH
1helpful
2answers
Why are all the lights on LCD screen on?
How to troubleshoot and fix video problems
Here are some tips and tricks for troubleshooting and fixing laptop video problems. Video issues are very common within portable computers and with the following tips you should be able to detect and eliminate basic laptop video problems.
Laptop LCD screen has a faint image.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the backlight stays off even when you open the LCD screen or turn on the laptop. The switch turns off the backlight when you close the LCD display to save the laptop battery power. Check the LCD lid close switch. Usually it is a small plastic pin located close to the LCD hinges. Try to tap on the switch a few times to turn on the backlight. If after tapping on the LCD lid close switch the backlight stays on, you fixed the problem.
It is also possible that after tapping on the LCD lid close switch the backlight works fine, you see a normal video on the screen for some time and then the backlight turns itself off again. In this case I would blame the FL inverter board. Try to reseat cables on both end of the FL inverter to make a better contact between the cables and the FL inverter board. If it doesn't help I would try to replace the FL inverter board.
Laptop LCD screen is solid white color.
http://www.laptoprepair101.com/wp-images/white-screen/1-laptop-white-screen.jpg
Most likely it is just a bad connection between the LCD display and the system board. I would try reseating the video cable connector on the back of the LCD screen first and check if it fixes the problem. After that I would try reseating the video cable connector on the system board. I would also try reseating cables if there is no video on the LCD screen at all.
http://www.laptoprepair101.com/wp-images/bad-laptop-video/washed-lcd-image-1.jpg
Try to connect the LCD screen to an external monitor. If the external video is fine, you have a problem with the LCD screen or the LCD video cable. You can try to fix the problem by reseating the video cable on the back of the LCD and on the system board.
If you see the same garbled video output on the external monitor most likely it is not the LCD screen problem. In this case the system board (with onboard video) is bad or the video card is bad.
REFERENCE: http://www.laptoprepair101.com/troubleshoot-fix-laptop-video-problems/
GOOD LUCK.
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Laptop screen is very dim. There is a very faint image. The LCD screen is brand new so that's not the problem
As per your description, it is probably your inverter which is faulty.
The inverter is an electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen correctly.
To test if the inverter is defective, just turn on your laptop in a dark space, then put a flashlight on the screen to see if you have a fainted display. If you can see something, it is the inverter which is defective and should be replaced.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself, but if there is no light coming from behind the LCD, then you need to replace the inverter.
Picture of an inverter.
Replacing the inverter:
1. After removing the screen 'cover', locate a small circuit board (usually below the LCD). Unplug the electrical cables and replace.
Hope this posts helps you.
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
1helpful
I have an NEC '19 Multisync LCD 1920nx monitor. The display went blank and will not come back on. There's power going to it. It just doesn't display and image. How do i fix this?....thanks
the inverter or the lcd bulb may be out. inverters are cheap, bulbs are not. is the screen dark like its off or glowing black? if its dark like the bulb is off, next, look closely and see if you can make out a faint image on the dark screen, if so, it is likely the inverter.
2helpful
LCD screen is faint XPS M140
You backlight is failing. That is the bulb that provides the brightness to the screen. You need to replace bulb which is very tricky to do unlesss you have experience or replace the screen.
Please rate this if helpful.
Thanks
2answers
Dell inspiron 5150 dark screen, faint image in background
If it showed a pinkish tint on the screen before it went out it could be the backlite. If you can see a faint screen when you turn the room lights out it chuld be the inverter. Inverters are cheap ... a used one for around $8 on ebay. Try that first. Make sure that you buy the EXACT model that is presently in your laptop.
2answers
I turn on my computer but the screen is still black
think you might have a failed screen inverter (FL inverter); this problem is very common with laptops. The inverter board acts as a power supply for the LCD screen backlight bulb, it converts low voltage DC power into high voltage AC. On most laptops the inverter board is located inside the display assembly below the LCD screen and you can get access to it if you remove the screen bezel (LCD mask). When the screen inverter goes bad the backlight will not turn on anymore or it turns on for a short time and then goes off, but you still can see a faint image on the screen and the external monitor works just fine. First of all I would make sure it’s not just a loose connection and reseat connectors on the inverter (it looks like you already done this part). Next, I would try replacing the inverter board. It might fix your problem with the backlight. It’s possible that you have a faulty cable, bad motherboard or even bad LCD screen, but I would try replacing the screen inverter first.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
