Question about Panasonic Televison & Video
How do i confirm clock settings on viera cast
Setting clock on Sylvania SCR4986
This is what i found:
Clock Setting
The clock can be only set while the unit is in standby mode
1. While the unit is in standby mode, press the TIME_SET button into clock setting. The LED
display will start flashing, press REV/DOWN or FF/UP to select 12h display or 24h display.
Confirm your setting by press TIME_SET again
2. While the unit is in standby mode, press and hold the TIME_SET button for 2-3 seconds, the
hours will start flashing, press REV/DOWN or FF/UP to set the current hour, press the
TIME_SET button to confirm the setting, then the minutes will start flashing, press
REV/DOWN or FF/UP to set the current minutes, press the TIME_SET again to confirm all
setting. The time is now set
Drew.
Jan 14, 2015 | Sylvania Audio Players & Recorders
How to get YouTube on tv
You must first run LAN line from the TV to your router.
Make sure the clock is set on the TV
Hit viera cast on your remote and you will be connected to the apps that are supplied to panasonic.
If you haven't already set up your internet. you need to do so through the user menu. Auto set up works best for novice users.
Apr 10, 2012 | Panasonic TC-P46G25 Flat Screen Plasma...
How do I get my tv onto YouTube Skype etc?
If you haven't already done so, then you need to purchase the camera for that TV. This does not come with the set. Once you have the camera hooked up and your Network set up. Push your viera cast utton on the remote and locate the skype i con in the menu
Apr 10, 2012 | Panasonic Televison & Video
How to get netflix streaming to my Panasonic Viera TH-50PZ80U
if your tv dose not have viera cast and if viera csat does not offer netflix
you will have to connect your computer directly to the tv with hdmi
Oct 30, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
I have a new Panosonic Viera TC-P54VT25. Everything seems to work well except for the sound on the Viera Cast. Viera Cast is connected through a hard wire ethernet connection directly into the TV. ...
I have had my Panasonic Plasma tv for 5 months there was a loud pop and the tv went off and now there is a red light blinking 10 times and the tv will not turn on.
Jun 15, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
I have installed a bridge on my network, but when I try to configure Viera Cast I keep getting the message "invalid DNS address, check your settings"
where is the solution??? The sideline said there was one!! I have the same problem and FixYa seems to be useless with this particular problem. Spent half a day fighting my TV setting, but no luck. Panasonic should specify what kind of devices can be used to connect their TV's to network: whether you can only use it with a wired connection going straight to your router, so you get DHCP/DNS resolved, or some other means. You definitely can't use wireless Access Point to get the Viera Cast to work. I tried bunch of modes and settings on my Access Point (Trendnet, both router and AP), but get the same error "DNS name not valid". What in the world!!! I get connection to my router, my DHCP is enabled, connection in Network Settings checks OK, but VIera Cast still gives me that DNS error. What gives??? Anyone smart enough around here to figure this one out? I tried both automatic and manual network detection, with the same results, even tried connecting another router to AP, which got connection right away, and thought I could full Viera Cast that way. No luck! What a useless option in a TV, when it doesn't work! FAQ on Panasonic's site are not helpful with this issue, either. No straight answer on the Net, either. HELP SOMEBODY!
Dec 19, 2009 | Panasonic TH-46PZ850U 46 in. HDTV Plasma...
Connection problems with Panasonic Viera Cast
I have had the same problem with my Panny DMR-BS850 which was resolved by changing the ethernet cable I was using which had only 4 contacts on each plug end for one which has 8 contacts. I tried all variations & combinations of IP & DNS before buying the new cable from my local pc store (£10 for 10m cable) and was relieved when setting the system to auto connect it worked within 3 mins. I think the slight delay was the router setting up a new address for the new hardware it detected.
My new cable states on it "Verified For Gigabit Ethernet" and is Cat 5e rated and I was assured that it will carry data for runs up to 95m long, which is contrary to the Panasonic support agent who told me to shorten my initial 5m cable to prevent signal degradation.
Give it a try.. it might just work.
Jul 13, 2009 | Panasonic Home Theater System System
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
Ferroli optimax HE 31C boiler
Setting time is not in manual that we received, however, we did get a separate sheet: Buttons top left-right are A - Clock adjustment B - Operating Mode selecting C - Override Buttons bottom left-right are: D - - E - Programmes F - +
To set clock: 1 - Push A 2 - When the DAY and the CLOCK icons on the LCD are flashing use + and - (D and F). You should set the day of the week (1 = Monday, 7 = Sunday). To confirm the day press A. 3 - The HOUR and CLOCK are flashing use + and -. Confirm with A. 4 - MINUTES and CLOCK are flashing use + and -. Confirm with A.
My LCD is not working correctly, so I have to press the screen gently to see what icons are displaying. Annoying.
Oct 29, 2008 | Heating & Cooling
Televison & Video Logo
530 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
