My wireless network adapter's device driver doesn't work
    Scholar:
  • 67 Answers
Download the latest drivers for XP or Vista
Note: If you can't find Vista drivers for Vista use XP drivers.
Uninstall the driver from XP or Vista.
If you have PCMICA adapter card in laptop remove it.
Reboot the PC
Note: If the network adapter is built-in laptop or PCI (desktop) leave it along.
Re-install the drivers and wait for the driver to tell you when to install the device if you have this option and don't have PCMICA card adapter for wireless.
If the card still doesn't work it could be faulty or OS is corrupted and needs to be re-installed. (this would be the last step to fix the problem)
Posted on Aug 01, 2008
Need Driver!
here's the link
I found that the Ralink RT73 driver seems to work with the Netopia TER/GUSB-N1. I found a form about how to install on a MAC maybe it will be helpful to you
Apr 26, 2013 | Netopia 3-D Reach (TER/GUSB-N1)...
There is a yellow exclaimation on my network adapter in device manager
This not necessarily cause for alarm. You can try to reinstall the driver for the device to see if that clears out the exclamation mark and, most cases, it will.
The exclamation mark simply means that Windows has found some sort of problem with the device. Double-click the adapter and see what the Device Manager's status says about it. This can, generally, point you in the right direction on what is wrong.
If reinstalling the driver doesn't work then post what the Device Manager status is for the device.
Jul 04, 2012 | Acer 91.AB370.001 Network Adapter
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
Sylvania net book doesn't see available wireless
If it's not seeing wifi networks, more than likely, there is something wrong with the adapter. Try these steps:
1.) Look for a WIFI switch on the side or front of your laptop and make sure it is set to the ON position. 2.) Check Device Manager to make sure the driver is installed and working. If it's not, uninstall and reinstall. 3.) Go into Network Connections and make sure the Wireless Connection is set to Enable. 4.) If none of that works, perform a System Restore to a time when everything was working. 5.) If this doesn't work, you need a WIFI adapter replacement.
I hope this is helpful and thanks for using Fixya!
Sep 23, 2011 | Computers & Internet
Dropped my laptop, nothing broke, but now my wireless adapter is missing and can't be found in the device manager or in the wireless connections screen. My wireless button is orange instead of its...
Hi
i would be tempted to go to
www.hp.com
go to support/downloads find your model and operating system and download another wireless
network driver and maybe that will make it work again its certainly worth a try
failing that you may have to replace the wireless adapter they are not very dear on ebay
hope you do get it sorted
Jun 23, 2011 | HP G60-230US Notebook
The wireless network adapter could not be accessed. this application may have dimnished finctionalty as a result. can you help me with this? inspiron 1525
There is a reason the wireless network adapter can't be accessed. It could be that you've turned off your wireless network. The driver for the adapter could be corrupt.
Check to see if it's turned on. If you access your network adapters, you should see if it is turned on or not.
If this doesn't help, from the device manager, remove the network adapter. Restart the computer and it will find the adapter and reinstall it. I think this will solve the problem.
Jun 13, 2011 | Dell Inspiron 1525 Notebook
How do I switch on my SONY VIAO Laptop to accept wireless internet, which I know is working fine
Depending on the model you own, most Sony Viao laptops have a small slide switch along the front edge.
May 27, 2011 | Computers & Internet
It does not connect
Wireless Adapter is a device that will receive the wireless signals and will make your computer wireless adapter. without the wireless adapter you can not use the computer to connect to the wireless network. Now a days all the laptops and desktops are equipped with the built in wireless adapters.
First check whether you have a wireless adapter on your computer ?
WIN XP
Right click on MY COMPUTER ==> properties ==> Device Manager ==>
you will see Network adapter ==> under network adapter you will see the wireless adapter ==> Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ?If it says working properly then that's great !
WIN VISTA/ Windows 7
Click START ==> Control Panel ==> In the right hand side at the top you will see " Classic View "
Switch to classic view ==> you will see Device Manager ==> Under Network Adapters you will find your wireless adapter listed . Right clink on the wireless adapter ==> properties => Check whether it says the Device is working properly or not ? If it says working properly then that's great !
If you do not see wireless adapter in the Device manager , then either you do not have the adapter or the wireless adapter is not working .If you see "yellow exclamation mark" on the wireless adapter, that means the drivers are not installed for the adapter or not working. Reinstall the drivers.
Once your adapter is working properly , try to connect to the wireless network.
If you are installing the external wireless adapter to the computer and if you are using Windows 2000 or Windows 98 , ME, then you will have to connect to the wireless network using the utility of that adapter.
If you are using Win XP then you can use windows to connect to the wireless network or you can use other utility.
In case of Win VISTA, you will use windows to connect to the wireless network.
Click Here for more info
Dec 09, 2009 | Dell 1450 (D1450U) Wireless Adapter
No IPX/Protocal found under Windows XP Professional
Haven't used windows in a long time, but from memory-and this is 5+ years
control panel/device manager/network adapter/properties/add protocol/IPX/SPX (Novell)/ok/restart
Mar 21, 2009 | Linksys Network Everywhere NC100 Network...
Lost the Driver for Linksys PCI wireless adapter, model wmp 54g
Go to your Device Manager and on the right side look and find Network Adapters. Expand the Network Adapter by clicking on it so you can see your Wireless Network Adapter. If it has a yellow exclamation on it then you need to install the correct driver, if it doesn have that exclamation the it may already have the correct driver. It may also be disabled ( red X) so enable it.
Check the wireless connection properties.On the "General" tab and in the middle look for and find "Internet Protocol (TCP/IP)" . Highlight it and click "properties". Make sure here that if you have set-up your router to connection type of DHCP that "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones checked.
Jan 25, 2009 | Linksys Wireless-G WMP54G 802.11g/b
Computers & Internet Logo
243 people viewed this question
David Payne
David Payne
