Question about Sharp Televison & Video
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
    Top Expert:
  • Sharp Master
  • 74,459 Answers
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Posted on Mar 14, 2011
Reset secret number on sharp aquos
ROFLOL and we are supposed to know it .or guess ,or read your mind from afar .
Nov 21, 2015 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp aquos lc-46le810un won't power on, psu diode zener and fuse blows..cause?
Unhook the PSU from everything that you can and turn it on, see if it blows anything out. If it does not then you are looking at a non PSU problem. If it does then it is psu. You need to get the schematics for this set if you can.
Aug 09, 2014 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp aquos tv will not power up
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 28, 2014 | Sharp Aquos Quattron LC-70LE733U
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Televison & Video Logo
311 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
