My hotpoint WD640 is flashing F08 error message. What do I need to do to fix it? Thanks N
    Brigadier General:
  • 6,277 Answers
For most Hotpoint (and other named) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause)
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
Sorry we cannot be of more help!
Good luck, John C
Posted on Mar 14, 2011
HotpointWMF fault F08
Heater Relay fault call Hotpoint
Dec 15, 2013 | Hotpoint Aquarius WD640 Front Load...
After starting its wash cycle an error code flashing F-08 appears Could you let me know the cause of this and if it can be fixed
For most Hotpoint (Indesit) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Apr 29, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
Disply screen flashes F-05
I have a hotpoint waschmachine wt640 since lastweek I have an error on the control panel F5 andnow it changes to F11 .The machine is just working for a few minutesand stop showing the error message F11 . please help
Feb 28, 2011 | Hotpoint Aquarius WD640 Front Load...
My Hotpoint Aquarious+ WD640 is leaking and has error code F-08 on the display. Should I panic?! If not, what's the alternative?!
Hi, I think F08 is a heater problem or a problem with the relay on the PCB.
Check connections to the heater element and even check around the element for leaks it could be linked!
if the cables are ok check for continuity across the element, if there is no reading then its likely the element needs replacing.
if the element and cables are good then it's likely the control board will need replacing.
If you cant check these things for yourself then consult qualified service personel and get a free quote.
Someone else here maybe able to suggest a better solution so please keep looking.
Hope I have been able to help.
Feb 09, 2011 | Hotpoint Aquarius WD640 Front Load...
Hi, Error code F-08 is flashing on the display.
F08: Heater control or NTC (Thermistor) temperature sensor problem. hope this helps. also turning off at plug for 5 mins then turning back on might solve it if does not then it is the sensor problem. best thing to call engineer or get new machine if dose not work. hope this helps.
Sep 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Machine is showing F-08 and has stopped
Error code F08 means that the heater relay can not be activated, check the following.
1-check all connections to module.
2-check the connections to the heater.
3- check the connections to the pressure switch. It is usually one of these components that is causing the error..
Hope this helps.
Dec 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Wd640 showing f08
Code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check control connections.
  4. Check and clean pump filter.
Please rate my sol;ution.
Thanks.
Nov 15, 2009 | Hotpoint Aquarius WD640 Front Load...
F-08
when f-08 flashes are any of the other led's flashing if so which ones.
Jun 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
315 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
