Question about Summit Appliances Division Mansfield 386 Summit 3 High Perfomance Toilet Tank and Lid
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
  • 24 Answers
There is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Posted on Mar 16, 2011
How do I increase the water flow into the tank of a Verona toilet
1.) Check to make sure that the water shut-off valve is all the way open (the water valve a.k.a. the shut-off valve is located behind the toilet near the wall or the floor, depending upon installation placement.) The water supply line attaches to it and feeds up into the refill valve assembly inside the toilet tank.
2.) Check the float assembly or the refill valve assembly, make sure it hasn't bound up by getting caught on another part inside the tank.
3.) Check the water level to make sure that it sits about 1 inch below the overflow tube in the middle of the tank. If the water is lower, adjust the float inside the tank to raise the water level. For models that have a ball float, turn the screw on top of the fill valve clockwise to raise the water level. For models that contain a cylinder float valve attached to the fill valve, squeeze the clip on the side of the float and pull the float up until the water reaches the desired level.
Feb 17, 2015 | Home
Why wont my have a cimarron k3489 toilet fully flush? the water empties from the tank but the water from the bowl does not go down.
That's an interesting one! Does the flush valve close properly so the tank can refill? Does the float valve allow the tank to refill fully, to near the top of the overflow? That can be adjusted, if it doesn't.
Check fhe flush valve - you may have an obstruction under it. Also check the water port from the bowl side - feel up inside the port for obstructions or buildup of hard water deposits.
WASH YOUR HANDS THOROUGHLY afterwards.
Jul 29, 2014 | Kohler K-3489 Cimarron Comfort Height...
The toilet tank does not refill automatically once the lever is pushed and the water flushes out of the tank. In order to get the tank to fill with water again after the toilet is flushed, I have to take...
Just replace the whole assembly. It only costs 12-15 dollars. Water contains so many minerals that just clog up lines like cholesterol. Just be done with it. It is not worth the effort to try to clean all that out . Plastic is sometimes not very forgiving.
Jan 28, 2013 | Toto Drake ADA Compliant Toilet with...
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
My daughters TOTO toilet kepted running so she turned off the supply line before she went to bed. when she woke up the next moring and turned the water back on, now the tank won't refill. How do I know...
There could be several reasons why it won't refill. It could be the fill valve, which can be replaced with a standard fill valve located at any hardware store. The more likely reason is the stem inside the shut-off of the toilet has broken off inside the valve. This is very common when a valve is older and usually doesn't get shutoff. If this is the case, a new shut-off valve must be soldered on.
Aug 29, 2011 | Toto CST743S Drake Round Toilet
How do I adjust the pressure in a Kohler pressurized flush toilet
You cannot adjust the pressure on the toilet. But you can adjust the stop setting screw at the top of the float arm. If the water is coming in too fast you can adjust the valve where the toilet water line connects to the wall water supply. Closing the valve a little will slow down the flow of water and it will take a little longer to refill the toilet water tank.
Mar 06, 2011 | Kohler - Toilet - Two-piece - Highline -...
We have installed an american standard duel flush toilet that uses a fluidmaster valve. Problem! The refill tube is mounted on a float attached to the overflow pipe. When the toilet is flushed the nozzle...
The overflow pipe should be attached to a small clip that holds it in position over the over flow pipe. If it is loose or attached to the outside it will do what yours is doing.
Apr 28, 2017 | American Standard 2480.516 FloWise Dual...
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
Jul 09, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Jan 05, 2009 | Toto Toilets ST753S 01 Cotton Dartmouth...
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Dec 26, 2008 | Kohler K-3360-G Revival One-Piece Toilet...
Summit Appliances Division Mansfield 386 Summit 3 High Perfomance Toilet Tank and Lid Logo
527 people viewed this question
Top Summit Appliances Division Home Experts
Donni Steen
Tom Chichester
Are you a Summit Appliances Division Home Expert? Answer questions, earn points and help others
