The printer cannon ir160is not pritning telling of papers waiting to be printed and now they are growing from 1- 7 currently
  • 85 Answers
SOURCE: Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Posted on Feb 15, 2009
  • 13 Answers
SOURCE: printer not printing
find the maintance section of your print driver display ( far right of the display ) should see a maintance tab.
do a cleaning cycle or a deep cleaning cycle and see what happens. it should start printing.
if necessary make up a solid single color block on a windows word doc using the squares make them no line perimiters and do a black blue red and yellow about 1/2 inch tall and 7 inches wide
as a test pattern. the color that doesnt print is clogged
in the future try not to let the inks run completly dry before they are replaced.
if that doesn't help use isoprople alcohol 91proof on a cotton swab or clean cloth and let the print head soak in it for 5 minutes and try again.
Posted on Feb 21, 2009
  • 2692 Answers
SOURCE: Printer has lines going through pictures when printed
See Canon FAQ from your model link below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402#SupportDetailAct
Posted on Mar 13, 2009
greg_margo
  • 1959 Answers
SOURCE: Paper size
Okay, go to your printer folder Start/Printers Right click on your printer (Officejet 6310) and click on Properties. You will see a button near the bottom called Printing Preferences. Here is where you choose your paper. You can make your choice here and choose to make it your default settings (click Apply to make the new paper your default to print your invitations...you will have to change back after). You may change the quality of print and paper type as well since the default setting won't provide the quality of print you desire. From here it's pretty straight forward. Feed your invitations into the paper tray as you would normal paper and try a test print for quality control. Once you've got the desired output, print the rest of your invitations.
Posted on Apr 20, 2009
Joed911
  • 4338 Answers
SOURCE: cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
Canon i850, i950, S600
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. release RESUME
3. press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
If I could be of furtheme know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 01, 2009
Cannon mp282 pixma ,how to fix error code 3
The E03 code indicates (1) That the Paper Output tray is closed and you are trying to print. Open the Paper Output Tray and the printer will resume printing. (2) There is a paper jam. Remove the jam, reload the paper into the printer, then press the "Black" or "Color" button,
Dec 25, 2014 | Cannon Office Equipment & Supplies
Why does the printer keeps having a paper jam fault on final exit slot?
It sounds like the exit sensor is sticking, so the printer doesn't know the paper has exited & throws a jam.
Aug 24, 2014 | Cannon Office Equipment & Supplies
I can't print out my document from my printer. cannon mf 8350 cdn
you have to set the format of the paper that you use in driver.
" out put size " A4 or else.
http://www.smoothprinterservice.com
Jan 24, 2013 | Canon Imageclass Mf-8350cdn Color Laser...
Please tell me how to enable duplex printing in my Cannon MP470. This option is checked on the printing dialog box, but only one side of paper is being printed. Thanks in advance for your help! SMK
The printing dialogue box may allow you to select duplex printing but you may have to physically turn the paper over yourself UNLESS you purchased a DUPLEXER for your printer.
If the paper feeds from the back and the finished product comes out the front, you will have feed the paper back into the back of the printer.
Apr 03, 2011 | Canon PIXMA MP470 All-in-One Printer
My IP 5000 Cannon printer says I have a paper jam but
Under the circumstances go to control and click on printer. Clear all the printing jobs. Switch off the printer and the computer. Wait for sometime and restart the computer and the printer. This should clear your problem.
Dec 20, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Downloaded driver from HP. connected printer via
HP Support says “If the Ready light is blinking, and the Go light is on, it indicates Data in the printer memory is waiting to be printed. Pressing the GO button prints from Tray 1 or from another tray if Tray 1 is empty and the paper size is supported in the other Tray. Pressing the JOB CANCEL button cancels the current job and the printer returns to ready.
Make sure the paper size is correctly defined.
Dec 05, 2009 | HP LaserJet 2100tn Printer
Cannon i960 blinks 1 green , 3 yellow etc... Won't print sayas pa
2. release RESUME
Thanks, Joe
May 01, 2009 | Cannon Canon i960 Photo Printer
I was printing in hp laser jet 1320n.....it was all going fine..but suddenly the paper got stuck in the rollers, while pritning a job. the paper is still stuck and just doesn't budge. what to do to release...
first you open the back side door of the printer and put down the two green lever and take out paer from there easily if possible clean fussing unit also.
Jan 10, 2009 | HP LaserJet 1320n Printer
Jul 03, 2008 | Lexmark T640 Laser Printer
12 people viewed this question
k24674
jasbo
jasbo
