Was washing when house tripped the circuit breakers..turned the circuits back on everything was fine but no power to washer.tried different power points but still no power to washer..power outlet where washer is usually plugged into is fine..model is WD-1248RD
  • sam cage Mar 14, 2011
    wheres the plug top???
    Sergeant:
    Novelist:
  • 196 Answers
Have you tried replacing the fuse in the plug top? Also try tilting the machine back to look underneath it for any signs of leaks. If it happened during the wash cycle it could indicate a faulty heating element
Posted on Mar 14, 2011
  • Michael Crozier Mar 14, 2011
    The power lead that comes out of the machine and plugs into the wall socket.
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
Spin cycle trips house circuit breaker on my GE top loading washer
The very likely reason the breaker trips only on spin is because the tub bearing is locked up on the washer since it is locked up its causing way excessive friction at the motor which causes the breaker to trip.Can you rotate the tub by hand or does it seem really hard to rotate by hand indicating that the tub is ceased up due to the tub bearing??
GENE
Oct 29, 2011 | Washing Machines
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
Circuit breaker only half working - reddish flag?
A red indicator means a circuit overload has tripped the breaker. You mentioned a heater? Does the circuit tripping coincide with the heater running? There may be too much load on that circuit.
Contact the original electrician to see if he will come check it out ( licensed, reputable electrician should have no problem with this). If he gives you the run around, find another. Was any aluminum wiring found in the home inspection?
May 01, 2010 | Bryant 40 Amp 2 Pole Br240 Type Br Ni...
The electrical consumer unit trips when the dishwasher is on, swicthing all the sockets off in the house. An electrician has told me it could be a number of things, namely a problem with the neutral, some...
You might need to contact a different electrician. Also a different retailer of machines as this one is obviously trying to make a sale. The apparent problem is that the house is wired with all of the outlets in the house on one circuit breaker--a recipe for trouble. Any house with multiple outlets should be divided into zones so that the whole house doesn't shut down if one appliance trips the breaker. A heavy user of power like a dishwasher should have it's own breaker and wiring for that machine alone. The electrician should have load-checked the dishwasher to make sure it is not drawing more than rated power, then suggested that it be wired to it's own breaker and circuit. Any other high power appliances should also have separate circuits (washing machine, microwave, toaster, etc.). Hope this helps!
Mar 25, 2010 | Tecnik TKL9260 Front Load Washer
Put washing machine on and it automatically trips
If it is tripping the breaker, the first question that has to be asked is how many other appliances do you have on the same circuit. When the washer goes to spin it will start to draw slightly more electricity than once its at a full spin(much like the energy needed to get a car moving is greater than once it is up to speed), but it is not enough to trip the circuit unless there the circuit is already near capacity.
Before attempting to check electric of the washer, check and remove items from the circuit. To know what circuit runs your washer you will need to take a pigtail or a radio and plug it into the outlet Go to circuit breaker box and turn on and off circuits until the radio goes out.. Once you acertain what circuit your washer is own, go throughout the house and see what circuts are shared with the washer. Unplug any that are shared with washer. Your Hotpoint needs no more than 15 amps to run but if your overloaded on the circuit, the spin is enough for it to trip the circuit. Try washer and see if you go through the full cycle.
Oct 13, 2009 | Hotpoint Washing Machines
Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
May 11, 2009 | Washing Machines
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
Washing machine causing power failure in whole
Best answer to this is the circuit outlet is connected to is overloaded < to many items are plugged into it > could be 15-20 watt breaker and usage amounts to more than wattage allowence. If you can lighten the load on circuit by removing things < t.v.,appliances,lights,etc.> from the other outlets that are affected < shutting down when breaker trips > then you can compromise and use washer any time. The other suggestion is to dedicate a breaker to washer, < by adding breaker and wiring to outlet for washer >.
Apr 22, 2009 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
