Question about Garden
I have a Bosch Aquatak 120i power wash and the nozzle at the top has broken off could you please tell me where i can get this repaired.I live in the Dublin 5 area. Regards David.
  • 24 Answers
I have not used this company, however they appear to do all the parts for your machine and do deliver to your area:
http://www.mtmc.co.uk/product.aspx?ProductID=28029
Hope this helps.
Posted on Mar 14, 2011
Shampoo will not come through
remove pressure nozzle or use low pressure nozzle only for shampoo
Apr 20, 2014 | Bosch AQUATAK 150 PRO X Pressure Washer
Not using shampoo
use nozzel with big hole or open nozzle up if adjustable
Roto power lance 'jet' keeps sticking
internal ceramic swivel is obstructed or broken, insert fine wire (supplied) into head then back flush head, or replace head, checkout ebay
Mar 17, 2014 | Bosch AQUATAK 115 PLUS Pressure Washer
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
Nov 08, 2013 | Bosch AQUATAK 115 PLUS Pressure Washer
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Oct 14, 2012 | Bosch AQUATAK 115 PLUS Pressure Washer
I have a Bosch aquatak 120i the motor keeps running all the time
Hello sir, that is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of time,not draining hose & machine, in the winter time the hose & pump will freeze causing hose & pump to expand and burst.handle to leak busting the o rings, build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps.thankyou. ~~
Feb 19, 2012 | Garden
Water starts to spray from the bottom of my Bosch Aquatak 120i when i turn the water on. Is it still safe to use when this is happening
Electricity and water can be a hazard which could be life threatening, but you can operate electrical equipment in a wet environment if you are careful and follow safety precautions. Most import, make sure the electrical outlet you are using for the pressure washer has a working ground plug. Just because an outlet has three prongs does not mean the ground is working. You need to use an outlet tester which is inexpensive from a hardware store or use a multi meter to test the ground for conductivity to earth ground. Your power washer should have a working GFI (Ground fault interrupter), and you need to press the test button to make sure it is working. If your power washer does not have a GFI purchase one from a hardware store. I would also plug the power washer directly into the electrical outlet since an extension cord could have a bad ground connection and will cause the power washer to pull more current from the outlet. Make sure the power washer is raised of the ground so it will not sit in a pool of water. If you follow the safety precautions you should be safe but keep in mind water does not carry the electrical current, it is the impurities in the water which carry the current. Therefore, water could be more conductive depending on the impurity of water. However, it sounds like a loose connection in the power washer which could also be an o-ring or a washer is broken and it would b a good idea to have it fixed.
Apr 29, 2011 | Garden
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
May 07, 2009 | Bosch Washing Machines
Garden Logo
201 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
