Question about Logitech ClearChat Stereo Headset Headset
I have a logitech vantage usb headset for the ps3 and i have plugged it an registered it with the ps3, i have set microphone volume up to level 5 which is max, but through the headphones when output is set to the headset i can barely hear others, how do i change earpiece volume on this item?
  • Anonymous Oct 26, 2008
    i cannot ear others in earpeice loudly ow can i fix it?
  • brainalishi Mar 17, 2009
    i have the same problem. it used to be loud on ps2 but my usb headset on ps3 is very quiet. any suggestions. i have scoured the settings on ps3 and exhausted them.
    Problem Solver:
  • 7 Answers
Just change the setting from your headset mic, to your tv speakers, works much better
on my piece of **** vantage mic i use to have (which sucks, im on my 2nd one, because of the mic (second one is currently broke also)) i couldnt understand them, plus when i turn up the tv volume how ever loud i want it
disadvantage
people shouting out random ****
(this happend to me)
some one shouted - **** my d**k **** my d**k **** my d**k **** my d**k **** my d**k **** my d**k **** my d**k **** my d**k, and on and on and on
so ya, good luck
Posted on May 26, 2009
How can i hear others loudly in earpeice?
Posted on Oct 26, 2008
How do i connect the headset in the game?
Posted on Mar 18, 2009
Hear myself through my headset
so to begin
1. right click the lil speaker on the bottum right hand side
2. select Playback
3. Right click you default speaker set, (for me its 2-logitech G330 headset)
4. select properties
5. go to Levels in the tab menu.
6. use the microphone slider and slide the microphone volume to 0
hats it your done, your mic will continue to work as normal with out the feed back loop in ur head set.
Aug 30, 2012 | Logitech USB Desktop Consumer Microphone
How can i attach a bluetooth to ps3 plz help
Hello my friend this should help you out.
please remember to leave a positive rating for me and a testimonial if I helped you out!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
and here's a video in case you are a visual learner.
Mar 26, 2010 | Sony Video Game Consoles & Games
Trying to hook my bluetooth headset to my playstation three what do i need to do
Bluetooth Headset Setup
In Game XMB:
All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
Feb 06, 2010 | Samsung WEP460 Bluetooth Headset
No sound or mike with ps3 headset.Logitech 980174-0403
go to settings/accessory settings/
and make sure that you ENABLE the audio setting = ON
also make sure that the mic is connected into the SECOND USB port or it won't work
Jan 20, 2010 | Logitech Vantage Microphone for...
NEW PS3 IS NOT FINDING HEADSET
JaWay (solution #1) is wrong. The usb cable is solely meant for charging the headset.
I had a few issues of my own. The manual is **** so don't follow that.
You mention somehting about a new PS3, taking that you have paired it before with another. Turn on the headset and press the reset button with the tip of a pen for a few seconds. The headset should now be reset and turned off.
Go to settings > accessory settings > manage bluetooth devices, from here you should be able to register a new headset. Initiate the search on your PS3. Hold the middle button for 10+ seconds. Till the led starts to flash alternating red and green. The PS3 should now be able to pick it up.
Sep 29, 2009 | Logitech Cordless Vantage Headset for...
PS3 Vantage Headset not working
its the update... mine stopped working after I updated my ps3... not sure what to do
Jun 08, 2009 | Logitech (980174) Headset
PS3 Vantage USB Mic Logitech
it might need to say guitar hero on the mic for it to read it
Feb 22, 2009 | Logitech Vantage USB Microphone for...
My ps3 vantage logitech mic stop working
call logitech  646-454-3200 then it ask u wat u want dial 1 1 1 then a technician will ask u what the problem is  then  say that u bought it  recently and tell him u can hear other people but u cant hear ur self on the mic then he will ask u for ur address and phone number then he will tell u that he will send u a new one free in 7 to 10 days
Dec 18, 2008 | Logitech ClearChat Stereo Headset Headset
I purchased the Logitech USB headset for the PS3 and PS2. I changed the accessories setting as the instruction manual indicated, but the graphic bar is set to the red region nearly at maximum even when i...
It sounds like you bought a bad apple on that one. I've never had an issue selling any of these. Logitech is the best company out there for video game and PC accessories, that's why they are the only ones with a Playstation emblem on their box. Just bring it back to the store and they should replace it for you no problem.
Sep 18, 2008 | Video Game Consoles & Games
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Logitech ClearChat Stereo Headset Headset Logo
385 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
