Question about Microwave Ovens
The 13amp fuse blew in the socket and when replaced the light and fan worked in the oven however no heat was produced...any help would be greatly recived the oven is a newhomes el616.
    Brigadier General:
  • 8,909 Answers
Door switches
If one of the door interlock switches is not switching properly or there is a condensation problem on the sensor control panel, either can cause the turntable/light/oven to come on even though the "Start" button has not been depressed due to the wiring of the switches or it can take the mains power fuse out and stay faulty.
Check for faulty door switches and/or contaminated actuators.
Alternatively, the magnetron, supply or HV diodes can fail and take the mains fuse out.
I hope that helps.
Posted on Mar 14, 2011
My miele combi oven microwave doesn't heat but oven is fine!
Probably a faulty door switch has blown the microwave fuse. If you are lucky.
Nov 17, 2017 | Microwave Ovens
Turntable, lights and fan inop
sounds like a cross wire, and a short. I'd inspect the socket for the bulbs to ensure that there's no short circuit.
Feb 11, 2008 | Magic Chef CMV1000B Microwave Oven
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
Microwave GE JES738 doesn't heat
Almost certainly the magnetron tube in your oven shorted and caused the light show and sound effects. This is the microwave source, and without the waves there's no heat. The tube is replaceable, but it's a costly parts. Add in repair labor, and you'd be better off replacing the oven. New ones are often cheaper than the parts alone today.
Apr 03, 2010 | GE JES738 Microwave Oven
Under cabinet microwave went cold today. Other electrical accessories okay
Most microwaves have an internal fuse. There is a good chance it is blown. Check your manual see if this is easily replaced. The other issue is of course why it blew the fuse in the beginning.
May 04, 2009 | Microwave Ovens
Samsung SMH7178STD microwave fan stopped working
It looks like the part of your computer board on microwave which responsible for controlling light and fan stop working. In this case you have to replace computer board.
Dec 03, 2008 | Samsung SMH7178STD Microwave Oven
Microwave won't heat anything
take the cover off the machine and look for a 13amp fuse that supplys the tranformers. BEWARE!!!
when you open the machine disconnect from the mains and do not touch the high power circuits the capacitors can hold a charge that can kill.
Jul 06, 2008 | GE JES1142SF Microwave Oven
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
50 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
