Question about Home
Tanita BF-592J - JennyCraig Scale .. we have owned this scakle since May 2010 and as of this weekend we started getting an error report .. we put in new batteries, checked the settings and are still getting the error .. when we touch either the setting for myself or my husband it flashed the appropriate info then goes to error .. when we touch the guest setting it goes to 88888 then to error your help is appreicated .. thank you
SOURCE: How do I set Tanita digital scale with 2 memory
Go to www.Tanista.com/ProductManual/PDFs/2001_manual.pdf
This should provide the answers you are looking for.
law4644
Posted on Jan 21, 2009
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
Posted on Jul 14, 2009
SOURCE: tanita innerscan stopped working. New batteries
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Posted on Jan 10, 2010
SOURCE: need to reset scale bf-681 tanita scale
I have a tanita body composition scale BC-534. It suddenly stopped working. I have new batteries. Is there a way to reset the digital disolay?
Posted on Jan 20, 2010
SOURCE: When setting Tanita scales specifics, after set, I get an error
I had the same problem with the error message coming up and emailed Tanita. The regional representative contacted me by email. He had me check with new batteries and clean the contacts. Then he cross-referenced my model and lot numbers and said that my scale was still under warranty and if it met the warranty criteria would be replaced. Tanita has a 10 year warranty on this scale and my scale was 5 years old. He gave me an RMA# to submit with my receipt and about 10 days later I had my replacement scale!! Fantastic Customer Service! Thank you Tanita!!!
Posted on Jun 17, 2010
Error code r5 on Tanita BF-350
Just spoke with Tanita Tech support- r5 indicates if the scale is in PC mode (able to receive data from scale). There is a button sequence to toggle between PC mode and stand-alone mode.
1. Press&Hold Zero button, then Press&Hold On/Off.
2. Release.
3. Arrow buttons toggle between PC mode and Stand-Alone, select which mode you would like.
4. Press Set button to select mode.
Hope this helps!
Mar 23, 2012 | Tanita BF 350 Pro Body Composition...
Does having water effect the BF calcutations on a Tanita 1250053 BF-350?
Yes. These systems work by what could be broken down as, "Bio-electrical Impedance Monitoring".
Meaning, they measure the amount of resistance in your body to determine the "volume %" of non-resistive materials (fat and water). Since bones and muscle are very dense in comparison, the scale can calculate the total weight of a person, then determine their "expected BF%). Fat is about 80-90% water depending on your genetic makeup, and it would only make sense that if you where full of fluids (either by ingesting large amounts or by fluid build up under the skin) that your BF% would read higher. My professional suggestion? Use it only after waking and before any morning drink or food.
(REMEMBER...THESE THINGS WILL NEVER BE EXACT!!!) Hydrostatic weighing in the only way to be 99%+ on your BFC (body fat composition)
GOOD LUCK AND PLEASE RATE THIS POST!!
P.S. one way to test this method is to hold something heavy in your hands and watch it consider that weight Lean Muscle Tissue. Then stick your hands in a sink full of still water (moving water posses a small electrical charge that could give a false reading) and watch your BF% increase.
May 09, 2011 | Tanita BF 350 Pro Body Composition...
Someone has switched my tanita BF 625 to metric readout and i don't know how to switch it back
Press the set and arrow UP button at the same time. Then use arrow UP to find lbs. Press the set button to confirm.
Jan 29, 2011 | Tanita Digital Body Fat Scale with 2...
Hello, my new device Tanita BC 532 measure weight and body fat%, but no reaction when I try to press rest of the featured keys. I use the description attached, and the weigth and fat% showes alternly on...
My Tanita BC-532 also developed this fault. It seems to be common with a number of the models! I asked Tanita and over a number of emails this is what they said:
"not to place it in wet rooms and remove the batteries if stored for a longer time period."
When I said it was in a bathroom (isn't that where everyone keeps their scales) NOT a wet room - they said any bathroom is classed as a wetroom!
When I said how can you tell if the batteries are just about to run out (that's what seems to trigger the fault) I had no reply; and when I asked how long is a "long period of time" - 2 weeks/ 2 months (we used to use ours every 1-2 weeks) again no reply to this question.
Now out of warranty after 5 years Tanita suggested it I didn't follow either of these instructions above (in the manual, but not defined) then I only have myself to blame. They did suggest one remedy was to:
"1.Take out the batteries.
2.Make a short-circuit between (+) and (-)with a piece of wire.
3.Put the batteries back and try it out.
If that doesn't work, you simply have to discard it. "
Personally I don't think this is satisfactory and I won't buy Tanita again. Scales should last much longer. They should make any warnings clearly defined - especially based on the number of times this happens according to reports from users on internet.
It seems this is a well known fault and I would thus suggest scales are not fit for purpose over longer term. Tanita should own up to this and stop avoiding their responsibilities.
Should you not keep in the bathroom, use every few days, and replace batteries before they get too low - then these scales are great (well they were for the first 5 years!)
Dec 25, 2010 | Tanita BC-533 InnerScan Body Comp Scale
Need to reset scale bf-681 tanita scale
Jan 12, 2010 | Tanita Bf681 Body Fat Monitor Scale...
Error reading 5
be sure you are barefooted when weighing yourself
Oct 05, 2009 | Tanita BF-350A - Body Composition...
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
Mar 26, 2009 | Tanita BC550 Innerscan Body Composition...
Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Home Logo
202 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
