Question about Casio Atomic-Solar MTG900 Watch
The watch is not automatically setting. how do i reset the time?
How do I reset a Marquis radio controlled watch that indicates the wrong time minutes?
Simultaneously press two buttons. It reset all, you show "Po". Press buton two (down placed) once quickly or more to set 12:00. Press buton 1 for longer as 3 s. You see 59. After watch synchronized if have good connection with sender, if not you must wait or adjust time by "hand". In Poland I must wait for automatic adjusting ca 3-4 hours.
Regards
Dec 31, 2012 | Stuhrling Marquis Gentry Watch
I have a Waveceptor 3353. If I change time zone I can usually set the watch to show ,say, Paris time both digitally and in analogue. When I try to go back to my home time zone, London, the second hand...
If you cannot find the automatic way of setting the hands, you can manually reset the analogue hands by pressing the mode button until you reach the "HS" mode and using the 2 or 4 o'clock buttons to adjust the hands.
Dec 30, 2010 | Casio DW9051B-1V Wrist Watch
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
    ANALOG TIME
    Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
    Oct 27, 2008 | Timex Watches
    Set date & time on radio-controlled Timex
    Hold down the split/reset button until the flashing tower icon stops flashing then release the button. The watch will automatically receive the next scheduled radio update.
    Apr 22, 2008 | Timex 27191 Wristwatch
    Casio Wave ceptor
    Check to see if the watch is set up to get its time from another country. You may find that the fault started with a battery change or an all reset of the watch. The default location for many of these models is for North America or Asia. In some models the location is not active until it is set. In different parts of the world, they are using different time set protocols. There are some technical reasons for this.
    Check the instructions about setting the time zone for the watch. Pay particular attention to the time zone setting, location setting, and that the feature is turned on in the first place.
    Jerry G.
    Apr 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    My Aquaracer Automatic doesn't keep exact time
    you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
    Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
    Daylight Saving Time will not set correctly
    Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
    http://world.casio.com/wat/download/en/manual/
    You will need a pdf reader on your pc, you will find all instructions in there.
    If you don't have a pdf reader you can get one from
    http://www.foxitsoftware.com/pdf/rd_intro.php
    Nov 08, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
    Casio Atomic-Solar MTG900 Watch Logo
    43 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
