Question about Toys
Here it is when this; active fault EEC 061 SPN004355 DEF Air Press 07 comes up my dd15 uses very little def my gas mileage drops off. what is this?
Ajkill
  • 2035 Answers
SOURCE: 2003 Grand Marquis
Check if the ac vent is blocked or the switch may in off position ,or selected the AC position on the ac control.....if does not help get it checked by the service center..............
Posted on May 29, 2008
SOURCE: A/C problem
Raise the hood and remove the right hand wiper assembley the remve the three or four plastic screews nad remve plastic cover . There is anothe cove to reme then pull out the cad filter do the carfull. The replace it with a new filter if this don`t work have you A/C system checked out, also the controles under the dash may be bad and need replacement.
Posted on Sep 23, 2008
  • 3 Answers
SOURCE: hi-def to standard def
lol big problem. cyberlink powerdirector must or can read the TOD files so that we can directly edit at powerdirector express we have to covert first the tod files to some file typles like avi, mpeg, i just figured out that nero 9 can directly read the tod files whaahay, now im using it editing the tod files,
Posted on Nov 10, 2008
Spencerjt
  • 17 Answers
SOURCE: getting a border around my picture
go to settings and change the resolution to 1080i or 720i
Posted on May 16, 2009
wireguy212
  • 1627 Answers
SOURCE: I get air flow through both heater and def vents
There is a stepper motor in behind the dash that controls where the air is distributed to.They are hard to get to,expensive to replace and almost impossible to repair so you might want to just live with it.
Posted on Nov 17, 2009
Testimonial: "That sucks."
I have a dd15 freghterliner 2011 with a fault code EEC 61 What do it mean
what engine has it go
if it is a GM detroit 60 series it is no 6 injector circuit board problem
heavy vehicle fault codes are specific to engine or transmission installed in what ever vehicle
take it to a service center for the engine make and have it properly diagnosed
Dec 01, 2016 | Cars & Trucks
Where can I find what the fault lites mean. on the dash of a Cascadia w/dd15
http://www.thetruckersreport.com/truckingindustryforum/freightliner-forum/240942-2010-cascadia-w-dd15-active-fault.html
Jan 06, 2015 | Cars & Trucks
Teco LS1209Y faults pre-def
How do you take the cover of to get to the filters
Oct 16, 2012 | Heating & Cooling
Activating HD mode
You do not activate or set the TV resolution at the TV, the signal feeding the TV has to be hi-def for the TV to show HI-DEF. TV will show what is being fed with, lo-def in = lo-def display.
Dec 09, 2009 | Sansui HDLCD1908 19 in. LCD TV
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
P0400
P0400 Exhaust Gas Recirculation Flow Malfunction
Post more information on your vehicle, and the symptons which lead to the fault.
Justin
Strictly Saab
Melbourne, FL
Aug 30, 2008 | 2000 Saab 9-3 Viggen
2005 Prius change in MPG after dealer service
What was the weight of the oil that was put into the engine when it was changed? Prius engines are VERY PICKY about the proper weight of the engine oil. Trust me. I see this quite often. The wrong weight oil can do bizzare things, and def lower your mileage. Something you can check: Take off the tube leading to the throttle body, and look down into the intake. Do you see any oil laying in the intake manifold? If so, you DEF have the wrong weight oil. This will NOT set a Check Engine light, either. Hope this helps.
Aug 19, 2008 | 2004 Toyota Prius
Traulsen URS36DT:
checking a def system is kind of easy. if you have located the defrost timer just turn the little knob on the timer until the unit shuts off, shortly you should hear "hissing and pooping" from water dropping on the heater. this lets you know that the defrost thermostat is good. if you dont hear this noise check your def thermostat and heater for continuity. if you put it into def and the heater comes on then you have a bad timer..
Dec 11, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Toys Logo
249 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
