Question about Philips GoGear SA3020/37 MP3 Player
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing happens. This has happened 3 times. It is NEW. I've just bought it.
    Problem Solver:
  • 5 Answers
It sounds as the battery has a fault. It is still under guarantee, so take it back to the store after backing up your music on your computer.
Best of luck,
Chris-ZA.
Posted on Mar 14, 2011
  • 635 Answers
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Cant turn on my mpio fl 350 because of discharged battery
Hey! I experienced the same problem as you, found my FL350 wich had been laying in a closet for 2 years, completely discharged.
What I did, was to connect the FL350 to the USB port, a message popped up saying like "USB device can not be recognized", ignore it, it will keep popping up, but don't mind that. I then left the FL350 in my PC with the PC turned on, and left it over night. Today I could turn the MP3 player on, resulting in that the PC found the device and it began charging. So I will leave it there, and in two hours I will go out running, listening to it :D Hope this works for you.
Apr 29, 2010 | Mpio FL350 MP3 Player
Mp3 player froze when plugged into pc. screen is blank but lit. is charged. what do i do?
Make sure the player is fully charged.
  • 1. Connect the player to your computer.
  • 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode,
  • 1. Turn device OFF.
  • 2. Slide the Hold switch down to Lock (orange color showing).
  • 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC.
Next Be sure the battery is charged
  • 1. Leave the player connected for approximately 2 hours to charge.
  • 2. Disconnect the player from the PC.
  • 3. Verify if you can turn on the player.
  • 4. Reset the player if necessary.
To reset the player:
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery but hooked to your computer.
Feb 02, 2010 | SanDisk Sansa e250 MP3 Player
Just got it for Christmas, loaded 500 songs with some room to spare, have been listening since Christmas day, and it just died on me today. It won't come on, and my computer doesn't recognize it. What do...
Make sure player is fully charged.
1. Connect the player to the PC.
3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.
5. Verify if you can turn on the player.
6. Reset the player if necessary.
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Next see this Tip here on this site I believe it will help you it helped me. >http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem< I hope all this helps you
Jan 02, 2010 | SanDisk Sansa Fuze MP3 Player
Creative Zen won't charge or be regonized by my computer.
I have a Zen Vision: M and often have the same problem if it is completely discharged and not used for a couple of weeks.
When I plug it into my laptop I get a message saying 'This USB device has malfunctioned and is not recognized" (or something like that) and the unit will not power on. However, if I leave it attached for about an hour it eventually comes to life.
Do you have a wall charger, or do you only charge bu USB from your PC?
My advice would be:
- Attach it via USB to your PC
- Leave is for 1-2 hours and (hopefully) is should come back to life.
If not, try a different USB cable - I used to use the standard USB cable that came with my Zen Vision: M to charge (and sync) with my PC, but recently my PC does not recognize the device when using this, so I switched to a different USB cable (the one that came with my Sony Ericsson phone) and now it works first time, every time.
Sep 17, 2009 | Creative Labs Zen Digital Media Player
MY SAMSUNG DOESNT WORK AT ALL. WAS LISTENING TO MUSIC AND IT JUST SHUT DOWN!! DOESNT REACT,THE COMP DOESNT RECOGNIZE USB... PLS HELP
try keeping it turned off for a while then it will completely drain the battery. then charge it for 3-4 hours. it will be working then
Aug 21, 2009 | Samsung YP-U3 MP3 Player
Mp3 charging problems
it sounds like the battery/cell is faulty.
May 14, 2017 | iSonic SnapBox X25 (2 GB, 500 Songs)...
Won't turn on
Try this;
1.) Turn on your MP3 player with 1 AAA battery or by hooking it up to a USB port.
2.) Let the player discharge completely & retry after some time.
call 1-800-800-8300. for support !!
Mar 18, 2009 | Mach Speed TRIO Onyx MP3 Player
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
Samsung YP K3 only lasts for 2 hours
1. totally discharge the battery so it wont come on.
2. Charge the battery fully
3. Reset the player
Now check how long the battery lasts. If it is still 2 hours there is a problem with the battey and you will need to return the player.
Oct 29, 2007 | Samsung YP-K3 MP3 Player
Won't Charge
I had the same problem. The next day I tried it again. It took about 5 hours to charge and then it froze. There were also songs on it that we had not recorded. This was in a sealed case! I took that one back the next day and got a new one. Today we charged that one and it only took about 2 hours. As soon as my daughter tried to go through the screens it froze again. You can't even shout it off! I am very frustraited!!!!!!
Dec 27, 2006 | SanDisk Sansa e250 MP3 Player
Philips GoGear SA3020/37  MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
