Question about Simplicity for Children Aspen 4-in-1 Deluxe Crib
The drop down side on the crib has a broken piece on it how can i go about getting fix
  • 396 Answers
This crib is on recall. Take it back to Walmart for a full refund of the original retail price, no receipt required. Take a printout of the link below. No problem!
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
Children have died in these. Please dont become a statistic.
Posted on Mar 14, 2011
How to I take apart the drop down side of this crib. I had it installed and can't figure it out
This is tricky but I have put it together and taken it apart countless times (3 kids, 2 houses and everyone switching rooms). All of the screws keeping the crib together need to be as loose as possible without the crib coming apart. I found it easiest to have someone help so they can help hold the crib. It's important not to pull the drop side apart as it will break the plastic slides (I've done this and had to replace them). Have your helper hold one side of the drop crib right against the side piece of the crib and slide the drop side down to detach it from the side your helper isn't on. once this side is detached do the same for the opposite side. On the crib side that attaches to the drop side is a "screw" that slides down the plastic slide and a "peg" at the bottom. I always get the peg out of the track and then you can slide the screw all the way down the slide to get it out.
Jan 04, 2011 | Cara Mia Louise Crib
The peace that goes to the side to snug in to the drop is missing...looking for that round piece ....any idea where i can find it
This crib is no longer being sold and Cosco no longer makes cribs at all. Drop-sided cribs are known for falling apart, having missing parts and children end up getting entrapped between the broken drop side and the rest of the crib and dying. Please, do not try and repair this crib, just throw it away. It should not be used for any child. Do not take the risk. It isn't worth it.
Sep 29, 2010 | Cosco Metal Crib
Drop side doesn't stay up
go to www.productsamerica.com
they have repair kits for many different cribs
Jul 03, 2010 | Simmons Mattress Baby Gear
Plastic piece broken on crib that has a drop side. An elbow shapped part that attaches to the wood side that is approx. 1'' x 2''
If you contact the manufacturer directly, they WILL give you the part for free. They would much rather give you a free part then have something happen, and them be liable for any injuries... Hope this helps!!
Dec 24, 2009 | Simmons Mattress Crib 'n More
Broken Hinges
Sounds like you have one of the cribs that was recalled for that very reason. They will send you the right parts for free to fix the 'drop side trigger lock' that was recalled, even if you didn't register the crib. This is their phone number: 1-800-816-5304,
This is the website http://www.deltacribrecall.com/
Hope that helps!
Jun 24, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Kinderkraft crib model 710
On the bottom of the front rail that drops (the drop rail), there are two plastic tension pieces (one at either end) that engage the two fixed, bottom rail slider hardware (the long, narrow pieces screwed top-and-bottom into the lower, inside portion of the tall, upright crib ends). These tension pieces are spring loaded, and the outer edge of each one rides along the outside (i.e., the parent's side) of the two bottom metal rail guides. Their purpose is to supply outward pressure against the lower part of the drop rail - that's what you push against when you press your lower leg upon the bottom of the drop side of the crib to lower it. They insure that when up, the drop side locks safely into place. I suspect these tension pieces are your problem. It sounds like they are improperly installed. Good luck.
Sep 10, 2008 | Kinderkraft Vermont Crib
Plastic piece to lower side rial broke
If you have one side piece that works, I would like to buy it from you. Email bluewriter24@yahoo.com Thanks.
Jul 05, 2008 | Childesigns Bellmont Crib
The Dorel 3-1 convertible crib model # WM1633
Do not use this crib. This crib broke and caused my infant son of six months to get caught. He passed away on October 16th because of getting caught in this crib. I am trying to getting this crib recalled. Please Please do not use drop down cribs. They are entrappment devices for infants. 3 infants including my son have died in 2008 due to drop down side cribs. Please for your babies sake, take this crib back.
Jun 22, 2008 | Dorel Alexander
RITA BELLA CRIBS
I have a similar crib by Rita Bella. This is what worked for me.
1. Remove drawer.
2. Face crib's drop-side.
3. On left side of crib (based on you facing the drop-side) locate two allen head screws close to you. Unscrew them. A piece of wood in the front will drop. This is normal.
4. Push left side of crib outward (about 1/4") until you can see the metal pin that controls the locking function of the drop-side. It is near the bottom.
5. Pull out the bottom part of the drop-side so it's not in the plastic groove area anymore. This should get the right side out as well.
6. Tilt the drop-side -- the bottom part should swing toward you. When it is completely tilted, you will see the wooden groove in the side of the crib, and you can then remove the drop-side pretty easily.
7. Replace the screws. You may need an extra pair of hands to get all the parts in place.
8. Replace the drawer.
Feb 29, 2008 | Sorelle Rita Bella 15936 Crib
Childesigns crib part needed
I have the same problem and I spoke to www.productsamerica.com at 1-800-772-1041 this morning and they said that the childesign is no longer in production as far as they know and no parts available. They also said no repair kits available will fit it. I am stomped as to whether I should just go out and buy another crib now.
May 23, 2007 | Childesigns Bellmont Crib
Simplicity for Children Aspen 4-in-1 Deluxe Crib Logo
59 people viewed this question
Top Simplicity for Children Baby Gear Experts
Dennis Crouse
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Simplicity for Children Baby Gear Expert? Answer questions, earn points and help others
