Question about Ariston Technologies Washing Machines
Hi,my ariston AVTL 104,will not drain by using washingprogrammes. what can I do ?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
Why Ariston lbf51 washing and drying light rapid flash
AL03 - Drain Timeout (drain problems)
LED 1 (washing) and LED 2 (drying) flashing.
Probably the siphon of the apartment is clogged.
  • Remove the drain hose and make sure that is not clogged.
  • Drain water in a bucket.
  • If the dishwasher drains the water, clean the siphon of the apartment.
Dado
May 25, 2014 | Ariston Technologies LL65 Built-in...
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
Hi,I got an Ariston Margherita 2000.It does work well,but the end of the cicle the water doesn`t dissapear from drum.I tried everything,but nothing happend. Many thanks. Zsolt
Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Ariston Technologies Washing Machines
The dishwater will not drain.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Feb 06, 2011 | Ariston Technologies LL65 Built-in...
Water not emptying from the machine,
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
The Larder fridge part of my Ariston
sounds like the defrost drain is froze up use hotwater and blowdryer
Jan 29, 2010 | Freezers
How do you drain the Ariston GL4
is there a pet **** on the bottom under a plastic cap? you might have to take the cover off and I would recomend putting some boiler drains in the line for future draining,, all units of water heaters have drains and looking at the picture I see something sticking down on the bottom see if thats not the drain
Jun 09, 2009 | Bosch Ariston GL4 GL4 Point-of-Use...
Ariston awd121 washer will not complete wash cycle
I'm also having the same problem. I hate this machine!
Jun 28, 2008 | Ariston Technologies AWD 121
Smelly machine
problem is probably tjhat liquid detergent has been used - gives a smell loke drains. put on a boil wash without detergent and use powder detergent
Apr 05, 2007 | Ariston Technologies LBE12X Ariston
Washing Machines Logo
441 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
