Question about Cell Phones
I want conn_x1412 security code - Cell Phones
    Sniper:
  • 72 Answers
Get the imei at the back of the phone by removing battery cover and the battery then go to www.unlockitfree.com.click master unlocking code to enter the imei the master code will then be displayed for the phone
Posted on Mar 14, 2011
2003 Ford Windstar was driving down the road my blinkers and radio and ac and lights also quit working just replaced alternator a few weeks ago anyone have any suggestions please
start with good conn at both batt conn, alt plug & conn, ck ALL fuses. Doesn't sound conn w/ alt. Fuse, Relay or elec. short in the wire harness. Start w/ the basics.
Oct 21, 2015 | Ford Cars & Trucks
I have a vintage guitar made by Conn with serial number 79-0908, model C74 I need a manufactors date
Getting date information on lesser known instrument brands (Conn horns are one thing, guitars are another) can be difficult. in this case, Conn wouldn't have made the guitar, but would have sourced it from a offshore maker. I suspect it would be made by Samick. Generally, the first two numbers are the year on Samick products, so probably 1979.
Mar 01, 2015 | Conn Music
I installed a bulldog remote starter with keyless entry and the doors won't unlock or lock with remote, why?
Were the lock and unlock wires connected to the system?
Lock: Gray/White (-) @ 40 PIN CONN OF BCM PIN 27
Unlock: Gray/Red (-) @ 40 PIN CONN OF BCM PIN 26
Do you have a Smartpass key or a regular key? What bypass are you using for the remote start system?
Jan 09, 2013 | Remote Starter with Keyless Entry
I have completed a diagnostic test and i have found that my renault clio which is 02 plate has a fault code 1 body computer fault intermittent, fault code 2 ring decod.conn. no communication intermittent...
I have the same problem few days ago and found my solution on Fixya Expert Sources website. Here you will get all the top sources of your problem. All the sources of this site provided by top Fixya Gurus. Have a good look at the sources of the page. Go through thesources to find your solution. Hope it will help.
View Count:3
Sep 04, 2011 | Renault 181 Cars & Trucks
How to connect MS access in the visual basic?
This following code to connect vb 6 with access
place this code in module :
vb Syntax
  1. Global Conn As ADODB.Connection
  2. Global rs As ADODB.Recordset
  3. Sub Access_Connector()
  4. Set Conn = New ADODB.Connection
  5. Conn.Provider = "microsoft.jet.oledb.4.0"
  6. Conn.CursorLocation = adUseClient
  7. Conn.Open App.Path & "\SIS.mdb"
  8. End Sub
Below link might help you... http://www.functionx.com/vbaccess/Lesson01.htm
Please rate or vote me , if you like solution..
Thanks
sandeep
Mar 15, 2011 | Computers & Internet
Screen displays error code f3e2
This code means "BAKE/BROIL range over temperature"
Problem is in either temperature sensor or the control board. Check the temp sensor and wiring from it to the control board first (connector #3, contacts 8 and 10, violet wires) . At room temperature the temp sensor resistance should be around 1080 Ohms. Also check temp sensor for short to ground. If no problems found with the sensor - replace control board.
OBTW - for the broil problem - check the fuse inline with the broil element (continuity between Conn #2, wire 1, blue and conn #4, wire 3, red). It should read several ohms. Good luck!
Oct 12, 2009 | Whirlpool RF462LXSB Electric Range
How can i save the data inputted from a textbox to the recordset or to its table in MS Access?
If you want to save it in MS Access, you need an OLEDB Connection.
You need to declare few arguments first to accomplish your tast like, OLEDB Connection String, Connection, Data Adapter....
I'll write a simple program to show you.
Const cn As String = "Provider=Microsoft.Jet.OLEDB.4.0;" & "data source=path of Access file(2003) where you want to save input data.mdb;"
Dim conn As New oledb.OleDbConnection(cn)
Dim objda As New oledb.OleDbDataAdapter
Dim cmd as string = "insert into login (loginid,pass) values('" & TextBox1.Text & "')"
conn.Open()
objda.InsertCommand = New OleDbCommand(sql, conn)
objda.SelectCommand.ExecuteNonQuery()
conn.Close()
Copy and paste the above source code, and then tell me what happens.
If you got any more quries, don't hesitate to ask.
And If I was helpful, Kindly do Rate!
Regards,
Waqar.
Sep 03, 2009 | Microsoft Visual Basic 6.0 for PC
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Code for find the Ms access database size using visual basic
The way to get the database size is to point to the directory that the database is do a DIR statement with an output to a file as in DIR payroll.mdb>dbsize.txt and then read from the text file, the first field of the second line being the name (which you really don't need) then the size value of the database.
To import the text files using VB 8 use
'Imports System.Data.OleDb Dim conn As New OleDbConnection("Provider=Microsoft.Jet.OLEDB.4.0;Data Source=d:\path\filename.mdb") Dim cmd As New OleDbCommand("SELECT * INTO [import] FROM [Text;Database=d:\path;Hdr=No].[dbsize.txt]", conn) conn.Open() cmd.ExecuteNonQuery() conn.Close()
Nov 10, 2008 | Microsoft Office Standard for PC
Top box conns
your freeview box tv scart goes to the tv /the dvd goes to the aux on freeview and you can connect your vcr to the tv if it has a spare scart socket or the dvd player
Jan 14, 2008 | Computers & Internet
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
