My telefunken has a problem. The guy that tried fixing it says that the tv is in PROTECTION (the light just flashes and no picture or sound comes through. Please help
    Brigadier General:
  • 8,909 Answers
If the set is in protection mode, that is normally caused by short circuit line output stage, short circuit frame output stage, short circuit audio output etc. It shouldn't be too dificult to fault find, even without a service manual.
Look for an authorised Telefunken service centre.
Posted on Mar 14, 2011
Testimonial: "Thank you"
Telefunken Vegas 42'; model: D294U - 88 power
Sounds like the screen could have gone or the motherboard has something to do with it, try opening it up but be careful just to make sure everything is intact
thanks
Aug 06, 2013 | Telefunken Tablets & eReaders
Continued from no picture no sound just clicking
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 15, 2009 | Hitachi 53UDX10B 53" Rear Projection...
How to fix Telefunken tv mp162m'
i found out in my in dept probing around the line output transformer has gone so no tv it is to get recycled
Feb 14, 2009 | Apex Digital PF2020 20" TV
A repair question for the RCA M50WH74S
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
When the TV goes on protection there are only two possible causes.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
All: Appliance parts, electronics parts & more from PartStore.com
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Aug 18, 2008 | RCA HD52W56 52" Rear Projection HDTV
Re:telefunken tv M702-no picture but clear sound
Hehehe, it becoms Telefunken Radio now.
Have nice day.
Jul 16, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV picture wont come on, led light blinking, we have sound
Jun 30, 2008 | Toshiba 36HF73 36" TV
6times flashing red light on sony grand wega kdf-60xs955
you may have a defective tv.
the best recommendation is to file a complaint, record the entire time you turn the tv on and it goes out, and show it to the next person that comes to service the tv.
Circuit city has a complaint form that you can ask for.
I did this once for a guy that "tried to fix" this exact same KDF-60XS955.
hope this helps.
Jun 29, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Clicking sound!
Apr 11, 2008 | RCA P60921 60" Rear Projection Television
Toshiba Cinema Series TV won't turn on
We finally had a repair man out and he replaced 2 convergence IC. They were $80 each so get out the check book! Works fine now!
Dec 25, 2006 | Toshiba DVD Recorder AND Series2 TiVo...
Televison & Video Logo
745 people viewed this question
Top Televison & Video Experts
Electro Med Services...
