Question about Cameras
Camera sensor giving problems. Lines appearing. Not shutter. Is it worth repairing? Camera is 3 or 4 years old but much loved. amanda.fieldgate@btinternet.com
  • 35 Answers
Unless the camera has high sentimental value, it is probably not worth replacing. I assume we are talking about an SLR or DSLR? The value is in the lenses you have for the camera. You can replace the entire body for what I am sure they would charge you to repair the sensor. Its like a band for a diamond. The value is in the diamond, not so much the band.
Posted on Mar 14, 2011
  • amanda_fi478 Mar 14, 2011
    Thanks for this. Shall be sorry to bin it as it's been a wonderful camera, but only sensible thing to do.
  • mw341175 Mar 14, 2011
    Thank you so much for the rating! It is a shame to see a good camera go... but its nice to have a shiny new toy!
Error in display
Press the shutter release again. Take out the battery and put it back in a while (1-2 min). Reset the camera with the reset button.
If this doesn't work, take it to the Nikon repair.
May 30, 2010 | Nikon D60 Digital Camera
All of my photos have horizontal
Sounds like the sensor or stabilization circuit may be going bad and it may not be worth the cost of a repair. If the camera is less than a year old send it to Nikon for repair along with the sales receipt. if more than a year old; do you want to put more than $150 into it?
Apr 08, 2010 | Nikon Coolpix P2 Digital Camera
Problem with my canon powershot 460 when shooting in day light the picture will appear too bright and with horizon tal lines
Hi!
It's most likely a broken shutter cable inside the lens. The solution is to change the shutter. It should get quite expensive so I believe it's not worth repairing this camera.
Sorry for the bad news.
Tom
Oct 09, 2009 | Canon PowerShot A460 Digital Camera
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
White band suddenly began appearing on every image.
HI I AM SAGHA A CAMERA REPAIRER FROM MUMBAI, I THINK THE SYMPTOMS YOU HAVE OBSERVED ARE THE SYMBOL OF MINUTENESS & PERFECTION OF YOUR WORK.ANY WAY IT IS A COMMON PROBLEM OF SHUTTER BLADES OF 1DM2,IDSM2,IN WHICH ONE LEAF OF THE 2ND SHUTTER BLADE GETS DAMAGED WHICH GIVES WHITE BAND OF BRIGHTER LIGHT FROM LEFT TO RIGHT(NOT OF LINEAR SIZE). I THINK IT WILL BE LITTLE COSTLIER TO GET THE WHOLE SHUTTER BLADES REPLACED.IF U WOULD HAVE BEEN IN INDIA I WOULD HAVE GIVEN U SOME CHEAPER OPTION(LIKE REPLACING ONLY DEFECTIVE BLADE ONLY)WHICH NO SERVICE CENTRE WILL GIVE YOU.ANYWAY GET IT REPLACED FROM REPUTED EXPERIENCED REPAIRER & CHECK SLOWEST & FASTEST SPEEDS AFTER REPAIRING THE CAMERA.REPLY ME WITHOUT FAIL THANK YOU & ALL THE BEST.
Aug 02, 2009 | Canon EOS-1Ds Mark II Digital Camera
Horizontal Lines throughout the images
What Canon technician told you that your camera did not have a CCD? You sure that he was from Canon? And also the cost of repair would likely be more than the latest A480. Also note that you can get an A470 for around $70 these days. But no this is likely not CCD failure and is more likely a stuck shutter.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note that the article says to set your camera to 15 second exposure. This is not possible with the A430. Instead set it to manual mode, turn the flash off, and go into a darkened room. Take your picture there. Open the door while the red and yellow lights are flashing. Now the possibility for success with this method is not that great so don't get your hopes up. But it's worth a try before shopping around for a new camera.
May 30, 2009 | Canon PowerShot A430 Digital Camera
Horizontal Lines Thru Picture on R967 Camera
I suspect it is a problem with CCD sensor. Let me know if HP were willing to repair it for free.
Mar 08, 2009 | HP Photosmart R707 Digital Camera
Lines appearing on pictures even though lens is clean
yes it can repairable,and it is ccd problem or internal flexible pcb.
this actually referred to aperture system.
Jan 25, 2008 | Panasonic Lumix DMC-LX1 Digital Camera
Wierd pictures
This is caused by a shutter that is stuck open. Normally the shutter closes right at the moment that you snap the picture and allows the image sensor to record what it saw at that moment. When the shutter does not close as intended the image sensor cannot properly record the image. This is why here are the lines across your images. The shutter can stick either due to an impact knocking the delicate blades off their tracks, or due to dust or moisture contamination sticking them open or closed. If gently tapping does not free them; the camera will require professional repair. David Millier Advance Camera Repair
Feb 15, 2007 | Fuji FinePix A330 Digital Camera
Cameras Logo
112 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
