Hi, I need a replacement power lead for an MPX 60 - who would be able to supply me with one?
2 Suggested Answers
  • 8404 Answers
SOURCE: need driver for mpx-60 for windows 7
Please check the Microsoft compatability list (search it) and see if your printer is listed. If not, you will have to check with Roland. You might find a 3rd party driver. Alternataively, put your Vista or XP computer and have that "print server" run your printer on your network.
Posted on Dec 30, 2009
I have a lexicon mpx100 dual channel processor and a spirit powered mixer. could you tell me how to connect it to the mixer and does it need a stereo footswitch regards lawrence
Footswitch is just an option for activating MPX. There are a couple ways to connect, but easiest is to run cables from AUX outputs to MPX then return cables from MPX to 2 open channels, using them to apply effects.
Apr 01, 2011 | Audio Players & Recorders
Hi: no power from supply opened box and checked fuse - its ok! The computer had a virus and that was fixed restarted computer and it worked ok, the next day pressed start button and nothing happened....
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Mar 20, 2011 | Dell 250W POWER SUPPLY NPS-250KB...
I have a question, the Computer doesn't start, there is only the power led on on the back of the power supply, can you assist in troubleshooting the issue
Replace your PSU then test all leads that are attached to your hard drive sounds like a faulty lead of some sorts then
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty because a computer has to have an end to the circuit any fulty leads will lead to no boot up
good luck
Sep 17, 2010 | Hi-Pro Hipro 200W ATX Power Supply p/n...
Need driver for mpx-60 for windows 7
Dec 30, 2009 | Office Equipment & Supplies
I have a tiger mpx s2466n-4m. pc won't post.recognizes memory but wont go past bios and video shadowing? any help thanks! Just installed 2 AMD MP2600+ processors(wouldn't show any bios info)then went back...
Hello sir, hi, as I see it, your problem, can be anywhere in the PC, but I do suggest you test first these 5 parts on a separate PC, by swapping. Here are the possible 5 faults:
  1. Memory, even though is passes the counting on the bios, does the counting completes? i mean if your PC memory is 256 MB, it should count up to 256 MB.
  2. Processors, just make sure both are fine.
  3. VGA graphics card.
  4. Power supply box.
  5. Motherboard itself. To check this part, make sure all parts on the top 4 are good.
If all are considered tested and good. you may need to check other parts. So check for:
  • connections,
  • loose seating of video cards,
  • shorted or bad faulty DVD/hard disk drive,
  • plugged in USB devices, just remove them all.
  • reversed IDE cable, (the old one can be installed reversed)
The troubleshooting of your PC really takes time, But i do consider the motherboard to be the faulty one. Thats why we need to test everything before we consider the motherboard be the culprit.
Nov 22, 2009 | Tyan Tiger MPX S2466N-4M Motherboard
How do i replace the power swicth of my hp pavillion m1170 uk and where can i get one to buy?
First of all remove the side panel from the desktop to reveal the motherboard, get a pen and note down where all the wires leading from the PSU (power supply) goes.
There should be 1 large 24pin block connector on the motherboard also a 4 pin block connector near the processor, these are the most important!!! the others are power leads that go to various drives like your hard drive and CD/DVD drive.
Start by disconnecting all the leads. Once all the leads have been disconnected turn the desktop on its side (motherboard facing up), go to the back and unscrew the four screws holding the PSU in place and gently lift it out.
To replace the PSU just reverse the method.
Here is where you can get a replacement power supply >>>>>>
http://www.circotech.com/power-supply-emachine-power-supply.html
Good luck.
Aug 20, 2009 | HP Computers & Internet
Car radio/cd player replacement, wiring problem
Yes. Both leads need to have +12v for the device to function.
Yes. You can run a bypass to the battery to make it work.
Mike
Jun 28, 2008 | Car Audio & Video
No power cable
There is no polarisation on the input lead - It won't hurt the deck if you get it reversed. If you have a shaver lead that fits, that should be fine.
Matt
Apr 16, 2008 | Stanton STR8-60 Turntable
Noisy video on tuner input
Well, if replacing the tuner did not solve it, the next likely culprit is the power supply. Does it look OK on A/V cable input? You didn't say what brand this is but all the older Matshushita made VCRs (panasonic, sylvania, quasar, magnavox ond others) have power supplies that fail often in this manner spewing out noise that interferes with the video signals. Some of us know how to repair the supplies as they are usually not available for replacement.
Dec 24, 2007 | Panasonic AG-1980 S-VHS VCR
k24674
jasbo
jasbo
