Question about IBM x3400 Server
Sir, In our IBM eServer3400 At First we got Controll Monitor Error,we followed the steps you have given solution.But yet we get error in another two servers we followed the same steps but one server only got rectified another two has not rectified. Pls give solution to the problems.
  • IBM Master
  • 3,606 Answers
There is a great deal of bugs and fixes for your product from here:
http://www-933.ibm.com/support/fixcentral/systemx/selectFixes#Critical updates
Make sure its for the right model, and mainboard number, and operating system:
My suggestion is, to consult your local IBM dealer, and ask them what the problem
could be.They must know.
Its not easy to say, what the problem could be, but my guees is that, it could be software
related.Or entering a wrong parameter.
Specifies the name of the Monitor control server where the Replication Alert Monitor program runs and the monitor control tables reside. This must be the first parameter if entered.
sir,
At - luw.gif If you do not specify a Monitor control server, this parameter defaults to the value from the DB2DBDFT environment variable.
zos.gif The default is DSN
Here is the trouble shooting site:
http://publib.boulder.ibm.com/infocenter/db2luw/v9r7/index.jsp?topic=/com.ibm.swg.im.iis.db.repl.monitor.doc/topics/iiyrcmonrasnmon0.html
Hope this was helpfull.
Posted on Mar 14, 2011
How to reset error E000-000 for Canon ir2202
To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
Jun 14, 2016 | Canon Office Equipment & Supplies
Getting error message on ibm x3400 Fatal Error Controller Monitor Failed Controller Not Started
dear sir in my server IBM X3400 has a problem due to RAM it might be corrupted or out of order bcause system gives continues beep when i change the RAM with HCL 1 GB DDR2 (Previous RAM was also 1 GB) it gives error:
waiting for controller to start
FATAL ERROR: controller kernel self test failed
<< press any key to continue>>
please solve the problem
Oct 28, 2010 | IBM x3400 Server
Fetal error controller monitor failed x3400 ibm server
Welcome to fixya
Open the server and take out the raid controller . Now clean the slot as well as the raid controller . Now replug the raid controller check if it works
If you get same error now , then its time to replace the raid controller
Thanks
Oct 13, 2010 | IBM x3400 Server
ISSUES WITH MONITOR,WITH ERROR MSG AS CONTROLL LOKED AND CONTROLL UNLOCKED and contrast,brightness msg appear often even though i dint press those butttons in monitor
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Aug 24, 2009 | SAMTRON 55V 15" CRT Monitor
Ibm server eseries255 error 289
If users try to send more than the maximum allowed data, Domino returns an error
read this red books reference, i hope this might help you.
http://www.redbooks.ibm.com/redbooks/pdfs/sg246495.pdf
http://www.redbooks.ibm.com/redpapers/pdfs/redp3851.pdf
Mar 23, 2009 | IBM eserver xSeries 360 8686
My laptop ( IBM thinkpad x31) won't turn on
GO 2 CONTROLL PANNEL .DEVICE MANERGER .MICE AND OTHER POINTING DEVICES ,RGT CLICK PROPERTIES CHECK C IF THE DRIVERS WORKING ? HAVE FUN !!!!!!!!!!!!
Feb 20, 2009 | IBM ThinkPad X31 2672 Notebook
Unable to install HPw2007 Monitor
I would like to inform you that if you are using HP PC, then there is no need to install the drivers from the disc provided with the monitor. HP PC already has in-built monitor drivers. The default account in Vista from first boot is an admin account, monitor should plug and play and the correct INF file will install for the monitor.
Still, if you want to install the drivers from the disc provided with the monitor, then please follow the steps given below:
== Disable UAC settings ==
You might get access denied error message while installing the monitor drivers.
The error message might come up if the UAC (User Access Control) in Microsoft Windows Vista is kept enabled, hence not allowing the installation.
To resolve the issue please follow the steps given below :
1. Click Start
2. Click Control Panel
3. Click User Accounts and Family Safety
4. Click User Accounts
5. Click Turn User Account Control On or Off
6. Uncheck the checkbox
7. Click OK
You will need to restart your computer for the change to take effect.
Now try to install the monitor drivers and check for the results.
If still the issue persists then :
Step 2 :
1. Click Start -> All Programs -> HP My Display -> Display Diagnostic Utility.
2. In the Display Diagnostic Utility click on “Clear Registry”. A Clean Reg Window would open, Click on “Yes”
3. On restart you will have “Other Devices” with “Generic Monitor” List under that same.
4. Continue the process of “Clean Registry” until you get “Other Devices” with “Generic Monitor” listed under that same.
5. Now insert the disc and install the drivers.
or Download the HP w2007 LCD Monitor Driver from the weblink provided below :
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39950.exe
Now install the drivers.
6. Restart the computer.
7. This time it says "new hardware found with recommendation to install".
8. Cancel it.
9. Immediately, it gives option "Do not show the message again" and also says computer won't function if we select it.
Proceed by check marking it. You may be prompted to check mark it twice if prompted.
10. Restart the computer to check for the error message.
It will no more ask to install the monitor drivers.
Take your time, please try the steps and get back to us with the results.
Jan 24, 2009 | Microsoft Xbox 360 Console
CRC1 0175 Error
This error is typical of a problem with the system board.
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4K2MCU
I've only seen this error appear on IBM thinkpads. Your EEPROM with the following steps.
You can try this to test the EEPROM
1.unplug AC,battery, HDD and and your cd/dvd rom drive.
2.press power button,last more than 10 seconds
3.plug battery and AC power
4.power on
5.when see the IBM logo,press F1 button immediately.
If the same error pops up, try it a few more times. If the error keeps displaying then it is the motherboard
Feb 23, 2008 | IBM ThinkPad A21m 2628 Notebook
Memory exception error in tally 7.2
I am facing this error in tally 7.2 memory exception error in tally 7.2 Pls help with a possible solution.cheeku
Feb 07, 2008 | Computers & Internet
IBM x3400 Server Logo
108 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
