I have a Brother MFC-6490CW multifunction printer,fax, scanner, copier machine that prints fine from my pc, however I am unable to scan either at the scanner or through the pc. I get an error message CC3-205-03031F04 when I try. Any suggestions on how to remedy the problem?
  • 35 Answers
Here is a post from the FixYa site from 2 years ago explaining your problem. It seems to be a problem with the IP address.
http://www.fixya.com/support/t678281-brother_mfc_9449cn_cc3_205_03031f04
Posted on Mar 14, 2011
My printing is fine in the morning but as the day goes on it fades.
Sounds like your printer needs a thorough manual cleaning. Go to printerhacks.com to get step by step instructions
Jul 03, 2015 | Brother MFC-9120CN - 17 PPM Multifunction...
My mfc 6490cw sends blank faxes
Normally this is caused by not loading the item being faxed in the ADF (Auto Document Feeder) correctly. Try sending a Fax of only one page by putting the page Face down on the Scanner plate (Lift the top of the printer to access the scanner plate). if this works then check the ADF scanner plate is not obscured.
Oct 20, 2014 | Brother MFC-6490CW Inkjet All-in-One...
UNABLE TO PRINT 44 - BROTHER MFC-J6510DW
User guide http://download.brother.com/welcome/doc002835/cv_mfc6710dw_use_busr_lx7144001_b.pdf says either a mechanical problem or could be foreign object like paper clip or torn paper inside the machine. Open the scanner cover to check for that.
Oct 15, 2013 | Brother MFC 6490CW InkJet Printer
Unable to print 32 printer brother mfc 9490cw
Unable to.....
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine
Sep 15, 2011 | Brother MFC 6490CW InkJet Printer
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
Brother 6490CW. The fax is set to print but it goes to memory instead. The machine is acting contrary to its settings.
Faxes always gather in memory so the whole image is ready to print, if there are any errors on the machine they wait and if there's lots of text the small memory will take longer to finally print.
Sep 16, 2009 | Brother MFC 6490CW InkJet Printer
Unable to scan to email with gmail on a Brother MFC-6490CW
Use SMTP relaying. Set up a computer with SMTP relaying. Go into the Remote Setup Program for your Brother MFC and select Setup Server. Use the IP address of that PC in the Server Settings and set Auth for SMTP to None. Worked great for me. This document can help you set it up on the relaying computer/server. http://www.lesolsoncompany.com/InstantKB20/Attachment17.aspx
Apr 01, 2009 | Brother MFC 6490CW InkJet Printer
Computers & Internet Logo
913 people viewed this question
David Payne
David Payne
