Question about LG WM2277H Front Load Washer
Was working fine then house tripped circiut breaker turned the breaker back on everything else is fine but no power on washer tried different powerpoints still no power
  • sam cage Mar 14, 2011
    sorry mate model is a WR-1248RD my fault
    cheers mate im in Sydney Australia bloody washing machines
  • 4,323 Answers
Hi
The issue is with the power control board going bad and should be replaced. If this board was fine and some other part was causing this then it would have shown an error code, as it's completely dead so the board went bad due to power surge and should now be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 14, 2011
    Guru:
  • 262 Answers
Check the incoming power to the control panel.
If you have power there and control panel is not responsive then the control is bad.
Here is a link to your models service manual.....when page appears look to the left and download your service manual. It will show you how to get to the control power to measure for power.
Please post results
click on the link http://136.166.4.200/contents/Laundry/WM2277.htm
  • Keith Drake
    Keith Drake Mar 14, 2011
    If this is a unit made outside of the U.S. I will not be able to help you. I entered the model number and came up empty.
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
Circuit breaker only half working - reddish flag?
A red indicator means a circuit overload has tripped the breaker. You mentioned a heater? Does the circuit tripping coincide with the heater running? There may be too much load on that circuit.
Contact the original electrician to see if he will come check it out ( licensed, reputable electrician should have no problem with this). If he gives you the run around, find another. Was any aluminum wiring found in the home inspection?
May 01, 2010 | Bryant 40 Amp 2 Pole Br240 Type Br Ni...
I have a brand new lincoln 180 mig welder when i hooked it up to 240 volt power it was feeding the wire just fine but when i tried to weld the wire would just stick , so i checked the power and found i was...
Have you tried it on another outlet, say at a friends' house, etc?
Reset button on the welder tripped? Double check the breakers and all connections. If it was working before, it should work now. Try some different breakers to check for good juice. Good luck!
Feb 16, 2010 | Lincoln Welding Tools
Washer tripped breaker on elec. panel, reset, washer won't turn o
This sounds like something has shorted causing the breaker to trip. You definitely need a qualified LG repairman to check it out.
Jan 11, 2010 | LG WM1814CW Front Load Washer
Rv electrical question
By the main breaker in the camper, do you mean the main 24 or 12 volt breaker, or the incoming 120vac breaker? Is it tripping the breaker in the camper, or the house? If it is tripping the breaker inside, i would look for maybe water damage, rusty components, maybe have an electrician come look at it, not worth going out away from home, and that problem ruining your vacation! Does this unit have a generator set? Try disconnecting the generator too. Hope that helps!
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Washer will not turn on. The knob moves but nothing happens when I turn it on. I've checked the breaker, the water, the plug/outlet, and hoses. Everything looks fine. But nothing happens.
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
May 05, 2009 | Whirlpool LSR9434PQ Top Load Washer
No electricity in all bathroom outlets
you may have agfi outlet in the circuit. the outlet has 2 push buttons in the middle. it maybe an outside outlet that is tripped some contractors hook up the circiut like that
Mar 09, 2009 | Siemens Electrical Supplies
Installing a Dayton G73
How many amps is your service? And what gauge wire did you use for the heater?
If your service is only 40amps that is your problem. You don't have enough amps for the heater and the rest of your house, you will have to upgrade your service.
Nov 02, 2008 | Dayton G73 Utility Heater
Hotpoint aquarius1100 electrical prob.
you say tripped the switch?... are you talking about a circuit breaker???.. I was thinking maybe you have a bad breaker... If you had no problem before... maybe try in a differt plug in reciptical... if the washer has a short.. hard to find sometimes..like looking for needle in hay stack..
Sep 02, 2007 | Washing Machines
LG WM2277H Front Load Washer Logo
53 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
