Question about Microsoft Wireless Laser Mouse 6000 v2.0
How can i disable the click sound of the mouse, this is driving me nuts?
  • aujacqui Mar 14, 2011
    thanks for your reply to my mouse problem, However the mouse does not have a sound setting for me to disable. any further help would be appreciated.
    Genius:
  • 1,400 Answers
Hello
Go to control panel.Mouse settings,sounds.... Then disable all sounds for mouse,hit apply then ok.
Posted on Mar 14, 2011
  • 1 more comment
  • mpcheesman1
    mpcheesman1 Mar 14, 2011
    Im sorry,try control panel,mouse,mouse properties.Then go to pointers,scheme.Then select none.This should stop the sound.I dont know if you loaded the mouse software that came with it.But this should override.
    Thanks for your further suggestion for my mouse problem. I have tried your suggestion but still have clicking sound. the sound is directly from the mouse not from my speakers. I don't know if that makes a difference to me trying to silence the mouse. many thanks for trying to help me. maybe ear plugs are my next best thing. :)
  • mpcheesman1
    Oh...The mouse itsself? No i do not know how to stop that.Im guessing there is a clicker inside that needs to be taken out.Problem is it will probably break the mouse.
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
How can I disable the trackpad to only use an external mouse? Toshiba laptop (Satellite)
For most Toshiba laptops, you should be able to hit FN+F9, and it will disable the touch pad. If that doesn't work, go to your Control Panel, Hardware and Sound, Mouse, and disable it there. Hope this helps!
Mar 28, 2011 | Toshiba Satellite 2400-S251 Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
How to enable touchpad I disabled by mistake and
Step 1: Click on Start and then click on control panel.
Step 2: Hardware and Sound......Devices and Printers....Mouse.....Mouse Properties.....Device Settings.....Touchpad.......Enable........(Windows 7).
In Windows XP
Dec 18, 2010 | Dell Inspiron 1545 Notebook
I have an acer laptop with multi-gesture tuoch pad that is driving me nuts. Can I make it function like a regular touch pad?
  • Hi, to Enable the Pointer Device; go to, Control Panel, click (Mouse) in the "Hardware and Sound" category. Go to; Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (enable) this being the Pointer Device. Click the Enable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, select Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out select to Update Driver2_bing.gif, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. "If this soluton helped, feedback is apprecited, paul7of9"
Feb 21, 2010 | Acer Computers & Internet
How do you disable the mouse pad on an Asus using Windows 7 ?
To “Disable” the Mouse Pad, or (“Pointer Device”), go to the Control Panel; select the (Mouse) in the Hardware and Sound category. Next select the Device Settings, in the (Devices) block, click on, and “highlight the item you want to (disable)” this being the “Pointer Device, this will also disable the “Mouse Pad” Click the “Disable button,” just below. “Always (“click”) on the, “Apply, and OK buttons before exiting.” Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. “Did this solution help? Helpful Rating Feedback, appreciated, thanks paul7of9.”
Feb 09, 2010 | ASUS Computers & Internet
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
How do I disable double-click on an HP Pavilion dv4 touchpad?
Hi there Dublin. I recently bought a HP laptop myself, and I believe I can help your situation, or at least I hope I can. Here's what you do: Access your Control Panel>Click Mouse>Click Device Settings>Click Settings> Click Tapping> Click Disable Tapping. That should do the trick. You are not disabling your touch-pad, just the double-clicking that is associated with it. Drove me nuts for about a day, 'til I figured it out..Hope it worked for your notebook.
Apr 06, 2009 | HP Pavilion dv4000 Notebook
Disable touchpad
Click start, ccontrol panel, right click mouse, click on properties and disable. If that does not work then try updating that driver. If it still does not work then go to MSCONFIG and disable it on startup and this will disable it permentaly
Feb 22, 2009 | Acer Aspire 4315-2490 Notebook
Microsoft Wireless Laser Mouse 6000 v2.0  Logo
91 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
