Posted on Aug 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mfc420cn brother fax machine
My fax machine will not accept or I can't dial out. I checked all the phone lines what else do I need to check. When I'm sending a fax it won't even dial the number please if you have any ideas I would love to know what I can do or what am I not doing. I have been using this fax machine for about 6 years so I'm not new to this machine.
thanks
Anonymous
Level 2:
Scholar:
  • Expert 159 Answers
  • Posted on Aug 02, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
159
Questions
Helped
72073
Points
207
Looks as if either the line cord is plugged into the wrong jack, or the cord itself may be broken. Last to check is the relay. To do this,1st unplug the line cord, then unplug the power cord. Wait 15sec, then plug in the power cord. After it has booted up and in the ready mode, then plug the line cord back in. If the machine is still not working, get an estimate to replace the relay. Usually you'll find it better to replace the machine.
What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue:
Check for a dial tone:
1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone.
If there is no dial tone, press Hook again and proceed to step 2.
If there is a dial tone, press Hook again and move to step 4.
2. Verify telephone cord/line connection:
Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side).
If the cord is already in the LINE port, proceed to step 3.
If it's connected to EXT, remove it from there and connect it to the LINE port.
Press Hook and check for a dial tone.
If still no dial tone, proceed to step 3.
If there's a dial tone now, move to step 4.
3. Test with a known working telephone:
Disconnect the telephone cord/line from the LINE port on your machine.
Connect it to a known working telephone and test for a dial tone.
If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider.
If there's a dial tone, reconnect the cord/line to the LINE port on your machine.
If still no dial tone, consider warranty and service options.
If there's a dial tone, proceed to step 4.
4. Remove splitters or other devices:
Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack.
If yes, remove them for testing purposes.
After removing any devices, continue to step 5.
5. Adjust Compatibility settings:
Press Menu/Set.
Navigate to Miscellaneous > Compatibility.
Choose Basic (for VoIP).
Press Menu/Set and then Stop/Exit.
6. Send a fax:
Insert the document face down in the Automatic Document Feeder (ADF).
Adjust paper guides to fit the width of your document.
Enter the fax number using the dial pad.
Press Fax Start.
Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance.
If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider:
Epson WorkForce WF-2750DWF:
This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen.
Features: Print, copy, scan, and fax.
Scan resolution: 1200 x 2400 dpi.
Dimensions: 16.73 x 14.17 x 9.06 inches.
Weight: 14.55 lb.
It's a budget-friendly choice for home and office use.
Brother MFC-L6800DWT:
A high-speed monochrome laser fax machine with additional features like printing and scanning.
Ideal for small offices.
Check out its performance and ease of setup.
Canon TR8620:
A multifunctional all-in-one printer, copier, and fax machine.
Offers versatility and functionality for various tasks.
Consider it if you need a reliable fax solution
On 6-4-2012 could send fax, now 6-07-2012 can't send or recievsed fax
Please check the settings on the fax machine. check the line to the fax and also the connectors, check using a phone to hear the dial tone.
If this seems good check if the fax dials the call, if not check the settings for pulse or tone and reset. If there is not dialling then the fax machine has problems that are serious which might need careful probing.
No fax sent or recieved
Have you taken and old phone and pluged the old phone into the wall and check for a good dial tone? Have AT&T to check your phone line, they will check the line up to the building, you check the rest of the line.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
When we attempt to dial to send a fax, all we get is beeping
Check your phone line with a regular phone. Your fax machine is not finding a dial tone.
Plug the phone line into the LINE port of your fax machine.
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
2answers
No dial tone
Very strange that there a no other symtoms.
Are you sure you are plugged into the LINE port of the fax machine?
2helpful
2answers
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Brother lntellifax 2800
If you have a hand set try to use it as a phone. If no dialing tones are present check the phone line connection. If the fax is well connected there is a good chance that you need a part for the machine.
2answers
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Norman Weimar
Norman Weimar
k24674
