Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
On my HP M1522 which i only use the photcopying function I have to keep turning it on and off to get the copier to work each time.
  • HP Master
  • 1,915 Answers
If your 1522 keeps freezing up, then it is likely that the formatter board is failing. Any M1522 manufactured before January 1, 2010 is covered by an extended service advisory, which means HP will replace your defective formatter. Check the serial number sticker on the back of the unit for the date of manufacture and if it is older than the date indicated above, contact HP and ask them to fix it for you. Or you can locate a local HP service partner who can do the work for you.
Posted on Mar 20, 2011
Tip
HP M1522 Freezes, does not start, blank control panel
If you have an HP M1522 and you are getting any of the following:<br /> <ul> <li>no display on control panel</li> <li>Unit freezes on start with "Initializing" or just arrows in display</li> <li>Printer will not power on at all or shuts off intermittently</li> <li>Unit stops functioning, appears frozen and control panel does not respond</li></ul> There is a good chance that your formatter is bad but there is hope for you.<br /> <br /> Check the back of your product for the sticker with the serial number on it. Also on that sticker is the date of manufacture. If your machine was manufactured before January 1, 2010, then HP has a service advisory that addresses this issue. A service advisory is an admission by HP that the product does not meet expected standards and as such they offer a free repair of the machine, regardless of the warranty status of the product. HP will replace the formatter on your machine and it will not cost you a dime. You simply need to contact HP at 1-800 HPINVENT. This service advisory is valid until December 31, 2011.
on Apr 17, 2011 | Office Equipment & Supplies
The photcopier was working well. but when I switched it on it showed printer error fuer temperature
there is something wrong with the thermistor or heater unit.
the thermistor function is for control the temperature of heater unit.
please check it all.
May 29, 2011 | Office Equipment & Supplies
M1522 mfp keeps showing door open
Hi cadlogistics,
Try a nvram. Hold down the down arrow and the cancel button while the printer is off.. turn the printer back on and hold until you see permanent storage init.
Al
Sep 07, 2010 | HP LaserJet M1522nf Multifunction Printer...
50.1 fuser error keeps appearing when I try to print/photcopy
The "fuser" unit is supposed to heat-up, to "melt" the dry "toner" ink into the paper, but your printer has detected that the fuser is not working.
Replace the _broken_ fuser unit, or replace the entire printer.
Jul 22, 2010 | HP LaserJet 2840 All-In-One Printer
My M1522 turns off after printing once. It has
it could be a power failure on the formatter board
Try doing a hard or reset or nvram:
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work contact hp, 1800-334-5144. If within 2 years from the purchase date ask for a case number to have the printer serviced under a service note.
Al
Eliteprintersolutions@gmail.com
Jun 17, 2010 | HP LaserJet M1522nf Multifunction Printer...
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Al
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
175 people viewed this question
Seeker5211
Seeker5211
