Question about Garden
My Countax C600H garden tractor is losing power. Can you suggest a solution. Many thanks, humemacdonald
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly.
This garden tractor came with 2 different engines. The 16 HP Honda and the 603 cc Kawasaki V-Twin. I do not know which one you have and the characteristics of each engine varies widely. I can help you but need to know which engine you have please. As far as losing power there are 2 main reasons an engine loses power. The first being fuel starvation from debris in the carb. float bowl and the second being worn valves and valve seats. More than 80% of the time it is a fuel related problem.
Turn off the fuel, remove the float bowl clean out the debris. Disconnect the fuel hose at the carb and check fuel flow to the carb. Things like fuel filters and tank exit ports can clog restricting fuel flow also. Using a spray can lid to catch fuel under the removed float bowl area the fuel flow with the gas momentarily on should fill the cap in around 8 seconds. If fuel flow is any less than that you need to find out why and locate the restriction. It can be in the needle / float valve area, carb manifold or before the carb. On the Kawasaki engine it can even be the fuel pump that is not working properly from a cracked rubber hose or a failed fuel pump.
If you can locate your COMPLETE engine number and post it here I can help you with some "how to" information that is ENGINE specific.
If there is a valve / valve seat problem your engine compression will be 110 PSI or less and will be very hard to start. Also you may note engine backfires during starting. Should you discover that you have low compression the fix is usually removal of the engine cylinder head(s), disconnecting the valve springs and hand lapping the valves and valve seats with coarse and fine valve grinding compound.
If you have the Kawasaki engine I can probably find an on line "Service manual" for your engine. A Honda engine on the other hand I do not have access to the service manual but the mechanical steps are very similar.
I am sure you have already replaced the spark plugs but... even something as simple as ONE bad spark plug and degrade engine performance drastically when under load.
Lastly... make sure the carb is not loose on the intake mount and that there are no vacuum leaks.
Thanks for choosing FixYa,
Kelly
Posted on Mar 14, 2011
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Countax c600h mower won't start! New battery last week today tho turn key and nothing. Lights all on, brake and seat switches good and even tried taking 12v from battery direct to starter
If you put a new battery in last week and it won't turn over now then you either have a short across the battery or the generator on the tractor has gone bad. A lot of times dead or low batteries will have enough power to turn on the lights but not turn over the motor. Disconnect the battery leads and put an ohm meter across them with the ignition switch turned off. You should see a very very high resistance.
May 14, 2016 | Garden
What is fault code 99 mean on a countax c600h 2011 many thanks
perhaps if you included the make and model ,year someone would know .
Feb 29, 2016 | Cars & Trucks
Where can I get a workshop manual for a Countax lawn mower/garden tractor?
I wish I could post the address to your mower, but there is not enough information. Start here:
Countax Tractors
or
https://support.ariens-uk.com/support/home
Dec 28, 2015 | Garden
As soon as I engage the blades the engine stops this has only just happened and it has been working fine until now you can start and drive it butnot cut This is a countax c600h thanks
Sounds like your seat switch may be defective not allowing you to run while the blades are engaged..it is acting like you got off the mower with the blades running....try temporarily bypassing it wire a piece of wire or paper clip..just disconnect it and put the wire ends in the connector ..if it is bad the mower will run with the seat empty and the blades running....CAUTION THIS IS JUST TO TEST IT..IT IS A SAFETY DEVICE AND NEEDS TO BE REPLACED...GOOD LUCK..
Sep 25, 2015 | Garden
Countax C300H Garden Tractor Manual
I have a countax 300h about 8 years out Will not start and a warning letter C is lit up any ideas what is wrong
Apr 04, 2012 | Garden
Where can I get a replacement cutting deck for a Countax K14 tractor mower?
Not sure of your geographic location but here is the contact data for Countax:
http://www.countax.co.uk/contact_us.htm Call them using the 0800 number on the linked page.
Parts link:
http://www.greenstripe.net/Parts-diagram/Diagram-405_Page-1.aspx
60 32726700 36 IBS DECK SHELL £300.11 view 60 32726601 38 IBS DECK SHELL £301.75 view 60 32726500 32766500_34 £302.82 view 60 32732500 48 DECK SHELL £265.49 view
If you not in the UK, I need to know your location please to locate other sources in your area.
Kelly
Aug 24, 2011 | Garden
Where can I download Countax E36 user manual from ?
Call Countax customer support, they will send you one free. 01844 278800
Oct 22, 2009 | Garden
Require an electrical circuit diagram for countax K18
Call Countax on 01844 278800, they're customer service is usually good at supplying this sort of info. Ask for a parts list and user manual while you're at it.
Jul 29, 2009 | Garden
Garden Logo
691 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
