Question about Gitzo Photography
One section of a leg of my explorer tripod has been unscrewed and is detached. I cannot figure out how to reassemble.
  • 93 Answers
Try the this video:
Posted on Mar 14, 2011
  • Turtell Mar 14, 2011
    It's really helpful.. Thanks
Leg stuck on Manfrotto 732CY tripod
Other than the leg locks themselves, sometimes Manfrotto expands the last portion of the leg tube that slides into the leg tube above it. If you need some spare parts you can find them here.
www.bogentripodparts.com
bogen and manfrotto are the same company
Nov 07, 2012 | Manfrotto Bogen 732CY M-Y Carbon Fiber...
Where are the batteries located in a Stanley Tripod flashlight
You'll need to remove the base of each leg by unscrewing the black cap at the bottom. Insert the batteries into the tripod leg. Each leg holds one to three AA batteries depending on the flashlight size.
Aug 24, 2012 | GE Photography
Manfrotto 685B locking problem
I had the same problem with the Manfrotto 685B, and it was due to the grease from the middle section leaking into its locking mechanism. I fixed the problem by: 1. Detach the middle from the bottom section by twisting the metal hub between them counterclockwise. 2. Wipe the grease off from the middle section's locking mechanism, especially from the three gray protrusions. 3. Use a bit of dish detergent to degrease the inside shaft of the bottom section. 4. Dry thoroughly. 5. Reassemble the section back, pressing the monopod release lever to facilitate the insertion. Reclose the metal hub. Ha! Fixed!!1!1!!eleven1!!
Feb 28, 2012 | Manfrotto BOGEN 685B Neotec Deluxe Monopod
How do you install the batteys in the stanley tripod legs?
To replace the batteries in each side of the 3-in-1 tripod light, you'll need to slide each light out of the central frame. Once each individual light is out on its own, you should be able to easily unscrew its bottom, giving you access to the battery compartment. Unlike the original Stanley tripod light, the actual tripod legs no longer hold the batteries.
On the original Stanley tripod LED light design, the black tripod leg tips simply unscrewed after you popped them out into the "stand" position. Much simpler to figure out.
Jun 25, 2011 | Stanley 3in1 Tripod LED Flashlight 95155
Hi, I have just bought the 190CXPRO3 carbon fibre
Little confused here. Is the head the part you want to detach from an older set of legs? Do you want to remove center post from new legs or old legs. The base plate remains on the center post/ Aftre removing 3 set screws, and you want to remove the head from the baseplate and it will not turn, grap slip joint pliers or a pipe wrench, wrap the jaws with cloth ( to prevent marring of head or legs) and while holding head with wrench, have someone else turn legs
Apr 26, 2011 | Manfrotto (190XB,128RC) Tripod
I need a new leg section for one of the legs on the G1257 tripod. The section I need is the lower section of the 3 in the leg. Do you have 1 in stock?
In the US, I think Bogen is the official distributor of the Gitzo products.
Manfrotto Distrubution
ATTN: Service Dept.
565 East Crescent Ave,
Ramsey, NJ 07446
201-818-9500
Hope this helps..
Andrew
Apr 03, 2010 | Gitzo G1257 Tripod
Reassembling telescopic sections for a 676B monopod
Each leg lock has a leg locking lever and a screw that hold the clamp assembly tight to the leg. Unlock the leg lock lever, loosen the screw above it that holds the clamp tight to the leg. The legs should fit into each other sice each leg is slightly larger or smaller then then next one. Slide the clamps in the approprite places and tighten the screw enough to hold the clamp assembly tight, but do not over tighten it. Over tightening will damage the 679 tubes.
Dec 25, 2009 | Manfrotto 679B Monopod
Is it possible to buy a replacement leg for a GB1140?
I would contact the factory and see if they have replacement part available. Try their website and ask. Most large retail manufactures have parts avaiable.
http://giottos.com/
Jul 06, 2008 | Giottos GB1140 Tripod
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
Photography Logo
308 people viewed this question
Top Gitzo Photography Experts
Tony Parsons
Tony Parsons
John Kahts
John Kahts
Level 1 Expert
Are you a Gitzo Photography Expert? Answer questions, earn points and help others
