Question about Clarke Power Products Clarke Crocodile Circular Saw Kit, Model# CT5000
Crocidle saw gear stripped - Clarke Power Products Clarke Crocodile Circular Saw Kit, Model# CT5000
    Novelist:
  • 157 Answers
Hello. Here's a link containing phone#s and emails to the main company themselves. They should be able to help you locate a reputable dealer nearest to you, as well as answer any technical questions you may have.
http://www.clarkeinternational.com/pages/clarke-contact-us
If this helps out please don
Posted on Mar 20, 2011
My Milwaukee 6215 does not oil the chain. I cleaned it and same result. How do I know i I need a new oiler?
You need to disassemble saw to get to the oil and check for stripped gears. If your saw is serial 746-1001 then the oil pump drive gear NLA.
Jan 07, 2015 | Garden
Maxtra long pole hedge trimmer has bolt with stripped thread.
same thing happened to me, I had to make another one there made of some kind of puter
Apr 07, 2014 | Maxtra Trimmer 30cc 2-stroke Gas Pole Saw...
Have a Dewalt reciprocating saw , and when turned on oh my goodness the noise that it makes ! screeching !! any ideas ???
Not sure of the model you have, but my guess is you have a stripped crown gear and armature gear (Very common problem for these tools)
Oct 18, 2013 | Dewalt Saws
How do you remove pinion gear attached to motor shaft?
with gear puller or press,sometime spring ring lock the gear on the shaft,remove it first
Nov 22, 2012 | Craftsman 10" Table Saw
Clutch adjustment on ryobi reciprocating saw # rj160v
The Ryobi RJ160V does not have a clutch, it has a direct drive system: the armature has a gear pressed on the end of it that turns a bevel gear with an off-set pin on it. This pin fits into a slot on the end of the saw bar assembly which is what you attach the blade to. If you have slipping it could be stripped armature gear teeth or bevel gear teeth or both or the pin on the bevel gear is broke off.
Feb 21, 2012 | Ryobi Saws
My saw blade isnt moving up and down. The jig saw sounds like its running just the blade isnt moving at all..... how do i fix it?
Unplug and Take the case apart. You will probably see that the gear moving the blade collet is stripped. Or, the gear fell out of place. Try putting it back together and see if it works.
Jul 08, 2011 | Saws
Reciprocating saw stops reciprocating upon pressure.
the gears are stripped, it cannot be easily fixed as the parts are not easy to get and tool must be heavily disassembled to get to them
Nov 14, 2009 | Saws
Can you tell me what is causing my delta mitre saw motor to run but the blade does not spin powerful enough to cut moulding?
Maybe the bolt which holds the blade on is loose. If the motor is on the RIGHT side of the blade, then the bolt has 'left-hand' thread. Turn it counter-clockwise to tighten.
Jun 19, 2009 | Bosch PRO1072SM 10 Inch 72T Miter Saw...
Clarke Power Products Clarke Crocodile Circular Saw Kit, Model# CT5000 Logo
119 people viewed this question
Top Clarke Power Products Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Clarke Power Products Measuring Tool and Sensor Expert? Answer questions, earn points and help others
