Hi with regards to my audio a7x monitor speaker... on the unit it says 2 options 220-240V 50hz 100-120V 60hz IT says use only with a 250v plug.. which i did:/ the speaker just doesnt turn on at all? Originally when i turned it on, there was a small crackle then the light faded out...
  • 32,281 Answers
You must switch the voltage option to match the mains voltage in your area.
If you have 220 or 240 AC volts mains voltage in your area and you have set the switch on your monitor speaker to 100-120 volts and then connect it to the mains supply then you have destroyed your speaker.
Posted on Mar 14, 2011
Hi, I ordered my Adam a7x from america to Australia. When receiving them, i plugged in australian adapters (300/500volts). But when powering them up, unfortunately the light went on and then a...
Did you just use adapters or actual step-down transformers?
A lot of equipment today is 110/220 auto-switching, but if you get something built for 110V (120V, 100V, markings may vary) only, then you need more than an adapter, you need a transformer!
Mar 14, 2011 | Adam Audio A7X Powered Studio Monitor (7...
Hi, I have ViewSonic VX2235wm-5 22"
It appear the monitor has been connected to another system unit than the default. disconnect the entire systems and reconnect altogether, restart the computer to allow the unit to recognise the new monitor. should diplay possible soluiton, else follow the instrcutions below
1.locate the control panel where the options of systems setting is displyed.
2. a click should dispaly a list among which is device speaker options
3. the computer speaker could be updated by clicking to install drivers or codes acquirable from the network.
alternately
1. click on the hardware icons located after locating and clicking into control panel.
2. on the list of add delete hardware provides the option to attempt to delete the speaker codes
3. a delete of the speaker drivers on system restart would prompt the user to update the speakers. A click on the prompt should acquire the necessary installation kit patches from an internet connection if any.
Dec 06, 2010 | ViewSonic VX2235WM Monitor
Can you buy an plug for this modle to pluge in at home.
European Players use 220-240V (50hz) while american ones use 110-115V 60hz
You need a step up VAC source.
Alternatively most (ie LG, Daewoo, Goodman etc) use a vatiable PSU. ie 100-250V which means you can plug it in direct. Just check the markings on your player.
Also keep in mind Uk, EU Africa use PAL, while the USA use NTSC. make sure your TV can display PAL too.
Feb 28, 2010 | Emerson Televison & Video
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Covert 230V 50Hz to 230V 60Hz
To convert to 50Hz will be expensive as the Aircon needs alot of startup power. You could ask maker if 50Hz will be ok, usually motor will run slower so unit will be less efficient, alway check with maker. Or try supplier to see if they will exchange for what you ordered first.
Dec 18, 2008 | Liebert UPStation GXT2700RT-208...
US portastudio 2488: Can it play when connected with a transformer
The 2488mkII manual specifies that the unit can operate with either 120VAC, 60Hz (USA/Canada), 230VAC, 50Hz (U.K./Europe), 240VAC, 50Hz (Australia) so you should be fine with a transformer which can accomodate 230VAC, 50Hz).
I have actually conversed with people who have been using the 2488 in France without any power problems.
Cheers,
bd.
Sep 12, 2008 | Tascam 2488 Portastudio Multitrack...
YST-SW215
Do you have the input voltage switch set to 120V 60hz. There is a switch that should change from 120v/60hz to 220v/50hz. In the US this should be on 120v/ 60hz
Jul 02, 2008 | Yamaha YST-SW215 Subwoofer
Have to change power input from 120V/60Hz to 230V/50Hz
ok " check the net for plug and power converters that plug in to
Singapore receptacle
Had a set for Europe worked great
Jan 22, 2008 | Miele CVA2660 Stainless Steel Coffee Maker
I have magnavox TV
you will need an adapter for it....
its the current frequesncy what he told you.. in US they use current of 60hz frequecny....
the place you live in use 50hz.. that is the reason...
see this link...it wil help you surely..
50hz to 60hz - For: 1.Use overseas to test products destined for use in the US or other 60Hz countries;
2. To operate 60hz machinery from a 50hz utility.
Jan 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
 Grubhead
Grubhead
