Question about Maytag MMV5207BAW Microwave Oven
Microwave model MMV5207BAW won't power up when pluged in. Outlet has power but microwave wont power up.
    Brigadier General:
  • 8,909 Answers
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Posted on Mar 14, 2011
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
Now power when pluged into outlet
Have you tested the fuse which may be faulty
Mar 27, 2014 | Whirlpool MT4078SKB / MT4078SKQ 700 Watts...
Hotpoint rvm1625sj01 no power
Hello
Plug the microwave into the outlet if the microwave won't power up. Make sure the plugs on the microwave match the type of outlet. A four-pronged outlet can only be used with a four-pronged plug. Same with three-pronged outlets---they only work with three-pronged plugs.
Inspect the plug. Make sure it hasn't been cut or tampered with. Four-pronged plugs can't be cut down to fit a three-pronged outlet. Three-pronged plugs mustn't be forced into four-pronged outlets. A three-pronged plug mustn't be used in a two-pronged outlet, either.
Replace blown fuses, or if there's a circuit breaker, check it for tripped breakers. Sometimes the trip won't be obvious, so cycle the circuit breakers. Turn them all the way off and then back on again.
Plug another appliance in the outlet. You will find this easier with three-pronged appliances. Simply plug a toaster, or other appliance into the microwave's outlet, and see if it works. If it works, you know the problem is with the microwave, not the power circuit. Have the microwave serviced or replace it. If the toaster or other appliance doesn't turn on, you know the problem is with the circuit.
Oct 04, 2011 | Hotpoint RVM1625 Microwave Oven
My Maytag over the range microwave is only 3 years old. No power. Changed the fuse - made sure the outlet worked on other appliances.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Apr 14, 2011 | Maytag MMV5207BAW Microwave Oven
I have a maytag microwave and the handle is broken, the model number is MMV5207BAW, I have searched for hours on the internet and cannot find a replacement handle, it is the white color microwave. Please...
You need too go too www.maytag.com and look for the microwaves, and look for a link for parts, if not you can call the maytag company and order one by giveing your model number.............
May 03, 2009 | Maytag MMC5000 Microwave Oven
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
I have Problem with my microwave
it may be just a fuse , but if the fuse inside the microwave blows again then there is something else wrong and it would need to be tested to find the problem and fix it
so the fuse inside needs to be check and or replaced and if the microwave powers and works ok after replacing the fuse , then the other fuse was just bad
Jan 11, 2009 | Emerson MW8108P Microwave Oven
No power- Outlet o.k.
open the housing, screws are on the back and sides. you can see some fuses there. check for continuity
Feb 18, 2008 | Maytag MMV4205 Microwave Oven
Maytag MMV5207BAW Microwave Oven Logo
123 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
