Question about Ricoh Aficio 1022 All-In-One Laser Printer
TECH SUPPORT HAD POWER SURGE AND NOW HAVE A CODE OF: SC546 WITH A CALL SERVICE CENTER message
    Problem Solver:
  • 4 Answers
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
Possible solution: Remove fuser cover, remove carbon buildup from thermistor.
I had to replace the fuser unit but it had 180,000 copies - service is 120,000
Posted on Jan 30, 2009
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
Service code SC546 on Model 5627
SC546 is universal in Ricoh, Lanier and Savin. It is indicating that the machine does not see the fuser.
Apr 26, 2011 | Lanier UNKNOWN
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
May 13, 2010 | Gestetner DSm622sp Digital Imaging System
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
Service code sc546 what do we need to do to fix this problem?
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 15, 2009 | Ricoh Aficio 1035 Copier
Lanier 5645 copier - Code sc546
Try this press the "yellow/ca" botton, then enter 1-0-7, then press and hold the "red" stop" till the display changes. Once, it changes turn the Main power switch OFF. Not the one on the control pannel. Let it power down then turn it back ON. If the problem is still there try to turn the copier Off again and unplug the sorter/ finisher and turn the copier back ON. Is the problem gone, if so you may have to get a service person come in and repair the sorter. Good Luck.....
Apr 06, 2009 | Lanier Office Equipment & Supplies
Help with code sc546
need model.but in most it's a fuser prob.
Jul 05, 2008 | Gestetner DSm645 Digital Imaging System
Service code SC546 on a Ricoh Aficio 1045
Clear yellow botton
7
Jun 03, 2008 | Computers & Internet
Ricoh Aficio 1022 All-In-One Laser Printer Logo
630 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
