Question about Whirlpool Washing Machines
Kenmore Elite washer keeps stopping and beeping. It flashes either DL or F or H. I push pause and reset but it does it intermittently. It tries to drain after these messages if I don't hit pause.
  • 5,911 Answers
Okay, it sounds like you may have a couple of things going on with your washer. The first link I'm providing explains the "FH" error and what you have to do to diagnose it:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
This "Fdl" error is generally caused by a failed door latch assembly. This second link explains how to replace the door lacth if defective:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
I would recommend you check the simple things first. Check to make sure you don't have a siphoning problem and make sure the drain pump isn't clogged. Then, I would recommend replacing the door lacth if the "Fdl" error keeps occuring. Some of these problems can generate multiple error codes. It could be that the door latch isn't working properly and is causing the washer to stop intermittently. Coupled with the possibility that you could have something clogging your drain pump. If you require additonal assistance, please post back and let me know. I hope this helps you.
Posted on Aug 01, 2008
KENMORE ELITE OASIS- comes up with a code: DL ( REPEATEDLY - CHECKED THE LOAD- BECAUSE IT STOPS- WON'T RESTART.
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hello, I have a Kenmore Elite Oasis washer model
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore Oasis Elite HE washer. I keep
Sep 11, 2009 | Kenmore Washing Machines
Kenmore Elite HE4t stopping in mid cycle with F abd DL errors
See Phoebe 112 latest solution! This is a common problem with these washers. For a quick fix you can usually get it going again by unplugging it for 30 mins. so the computer will reset. You will hear a slight buzzing noise when it resets. If it keeps doing it, go to the comment for Feb. 14, 2009 and try that if you are handy. Unplug the machine before doing any of this as with any machine that is electric or you will probably get the shock of your life.
Feb 14, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't start; has alternating "dl" and "f" errors....can't reset
This is a Door Lock Error. The service manual lists the following causes: Door Lock Mechanism is broken or removed from door. Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this). To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Oct 28, 2006 | Kenmore Elite 45986 Front Load Washer
Open Questions:
Washing Machines Logo
70 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
