Question about LG 42PC3D 42 in. Plasma Television
No power... Can it be the fuses? how do the fuse look when it blew?
  • LG Master
  • 2,098 Answers
Hi wrensch511,
Here are some basic steps that will help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I would advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts in the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact , don't attempt to touch anything because there some fatalcomponents stored electricity enough to hurt you with a simple mistake only. I would advice you to look for a professional to troubleshoot the power supply. If you want to repair it yourself make sure that you have necessary tools and test instrument. First check bad solder joints(re-solder all cold solder), leaky electrolytic capacitor(sometimes it has bulged at the top but not all, you better have a capacitor checker), open/shorted regulator transistor/IC(mounted in heat sink), open fusible resistor (caused by shorted regulator Transistor/IC), shorted zener diode.
You may also replace the power supply board, try online http://shop.ebay.com/i.html?_nkw=LG+42PC3D&_sacat=0&_odkw=d038+transistor&_osacat=0&_trksid=p3286.c0.m270.l1313
http://www.shopjimmy.com/catalogsearch/result/?q=LG+42PC3D
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using fixya.
Posted on Mar 14, 2011
2 Suggested Answers
  • 11800 Answers
SOURCE: I have a 2006 Hitachi Plasma 42HDS69 that will not
Blown fuse signals a massive short in the power source of the tv - it will have to be replaced. But before doing that you must find out why the source got fried and if other parts of the tv need replacing - the other components will have to be checked for shorts (as to not fry the next power board) and then the rest of the components tested.
Yes, the tv is repairable, but how much it will cost depends on the extent of the damage. But it will be at least $150 - the price of the new board - plus how much the repairman will ask to do the swap and test the result..
Posted on Feb 14, 2011
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
My power window and door locks fuse keeps blowing.
When the fuse blows figure out what you are doing, what switch is being pressed, then remove the needed panels to access the wiring to the switch and motor it operates, then you will find the damaged wiring and repair the short, no quick fix, just hard grunt work.
Mar 16, 2017 | 1996 Toyota 4Runner
I pluged in a small car vac in the power outlet , after ten minutes it blew. Owners manual dosen't say there is a fuse for it.
There should be a cig lighter-accessory relay in the box near the battery. It is powered by a 9amp fuse and a 20amp fuse. The 20amp fuse is in the same box with the relay.
These fuses and relay power the front and rear outlets.
Dec 21, 2012 | 1999 Dodge Caravan
My York Pacer 3500 Treadmill switched on then every time I used it the fuse blew. Its happened almost 5 times.
see the block diagram attached.
1) you must test the power cord for short wires.
2) test the power switch for short.
3) test coil for shot
4) test capacito for short.
5) the main motor board can be faulty
In short you must disconnecat every wires , and isolated the short for to avoid the fuse blown.
Otherwise you must call some service tech, from your supplier company.
God bless you
Jun 29, 2012 | York Exercise & Fitness
No power fuse blew
it means you have shorted regulator transistor on power supply..
It is usually fit in heat sink..
Try to replace it and the fuse again also check any fusible resistor near that transistor..
Feb 23, 2012 | SNK Magnavox 32MF338B27 32 in. LCD TV
Blows main fuse when power is turned on
Shorted power supply/module is most likely problem.
May 27, 2009 | Sony STR-DE635 Receiver
NPS-180EB A POWER SUPPLY SYSTEM DAMAGE DUE TO OVER VOLTAGE
well first is there a fuse you state fuse available not that one is there -----the surge didnt blow the breaker or fuses either if currant made its way to your components --as to why fuse didnt blow --- no fuse ---surge came through ground --surge blew something before fuse blew your case blew power supply
Jul 21, 2017 | Gateway 180Wt Power Supply NPS-180EB...
Blows fuse with no load
Sure sounds like your power supply has a short and should be replaced.
Oct 30, 2007 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
LG 42PC3D 42 in. Plasma Television Logo
797 people viewed this question
Computer Repairing
Computer Repairing
