On my ps3 i had a corupt hard drive so i repaired it frew the option menue since i have done that i cant play a saved file on justcause2 as a massage apears this save file cannot be loaded as it belongs to a different user.but the rest of my games are ok
  • 604 Answers
When you do a hard drive repair, bad sectors are eliminated, you should have seen a waring about this when your first started., That being said, you need to reinstall the game
Posted on Mar 14, 2011
Will not start
Your Hard Drive may be done for. The only thing you can do is buy another PS3 Hard Drive (Ebay, Amazon) and updating your PS3 while you are at it. Once your PS3 is up and running, you can put the corrupt hard drive back in and attempt re-format it (if you want to keep the old HD). However, you may be able to find a technician to do this for you without you having to buy another HD. Up to $70 for this repair would be a good deal. (an HD will cost you just as much)
Couple more tips:
- If you have an old style (Fat) PS3, the repair may not be worth it since they DO have a life span. Eventually, it will die for good. The repairs are only temporary.
- If they want to charge you more than $70, I would just save up another $70 and buy another one. (they will drop to $149 soon)
Hope this helps!
Jun 24, 2014 | Sony Playstation 3 (PS3) Console
How to fix Corupted file data for PS3
Reformat the hard drive - the setup menu allows you to do so.
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
When we play ps3 and we try to change the options in the game the error 8003051E comes and the file does not save. even during the play the game cannot authomatic save. so everytime we need to start from...
HI,
Things You'll Need:
* PlayStation 3
* External hard drive
Unplug any external hard drive that may be attached to the PS3.
Restart the PS3, including unplugging it and plugging it into the power supply again.
Format the file you are trying to save to be less than 2 GB in size. The main reason you are getting this error (game will not save) is due to the large file you tried to save.
Connect the external hard drive to your PS3 again and save the file. The error should not occur again.
Oct 11, 2010 | Sony Playstation 3 (PS3) Console
File is corrupt ps3 COD modern warfare 2
if its corrupted it may have not saved proprly and he will have to start over again, u cant use corrupted data on any thing not just ps3
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
My PS3's hard disk file system is corrupted
This is happening because your console is not recognizing the HDD (hard drive) for what ever reason. The corrupted files are about to do damage to your console, and a PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the HDD reset menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console just won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, Indra!
May 30, 2009 | Sony Playstation 3 (PS3) Console
360 recovering gammer tag
well if your on live try formating the hard drive and clearing the cache
heres how
Clear hard drive cache
Turn on the Xbox 360 while holding A to remove old cache files from the hard drive. Note: Your saved games and media will stay intact, however downloaded game updates will be deleted. They can be restored by playing the game again while Xbox Live enabled.
Enter the "System" menu and select the "Memory" option. Highlight the hard drive, then press Y. The Device Options screen for the hard drive will appear, with "Rename" and "Format" options. Press X(2), LB(2), X(2) to clear the cache. Alternately, enter the "System" menu and select the "Memory" option. Press Y for device options, then press either LB, RB, X(2), LB(2), X(2) or X(2), LB, RB, X(2), LB, RB. You will get a message stating that the system is performing maintenance.
Jul 16, 2008 | Microsoft Xbox 360 Console
Playing mp3 songs on the ps3 --- 80gb
Whether you are hooking up your device through a USB cable or removable memory (SD card/Flash drive) the PS3 should recognize and play the titles. Here are a few steps to help you along.
1. Hook up device to your PS3
2. Select PS3 media icon where files files should be located
3. Press triangle button on controller
4. Sub menu will show up on side of screen
5. Select the 'display all' option
6. Files should now be accessable/loadable/playable
Playing files directly from the Mp3 player or loading them on the hard drive are both do-able and both methods should work.
Jan 13, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
