Unable to drain the cycle water and therefore unable to retrieve washing stuck in the machine.
    Brigadier General:
  • 6,277 Answers
Sorry you do not say the make and model of your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking both the filter and the motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 14, 2011
  • 2 more comments
  • chantalschur Mar 15, 2011
    Brilliant! Thanks from a US Army military wife in Germany who is fixing appliances without help! (yikes) Your suggestion worked perfectly. Besides a lot of hard water residue, I found a coin, a lollipop stick, a bebe pellet and dog tags! I'm impressed it was working at all! Thanks again!
  • john_cross Mar 15, 2011
    You are very welcome!
    John C at FixYa
  • kateinmunich Mar 17, 2011
    I would like to clean my drain motor thingy but I can't get into it. The acess lid won't turn far enough for it to open. I saw a very complicated explanation in german for taking off the whole front of the machine in order to get at the drain motor when the normal access is blocked. Is there anyone out there who could explain to me how to do this in english?
    Many thanks in advance!
  • john_cross Mar 18, 2011
    Absolutely!
    Had the same problem with our Bosch, cap would not even turn!
    Suggestions-
    pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
    I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
    I now run an anticalc clean regularly............which reminds me..............!
    Good luck
    John C
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
I have a WM2277HS TROMM Washing Machine and at the end of the cycle the water does not drain nor does it spin. Therefore, the rinse & spin cycle only rinses but does not drain the water nor spins. ...
Sounds like a bad lid switch. Check to see if you hear a "click" from the switch when you open and close the lid. If you do not, then you should replace the lid switch.
Nov 26, 2010 | LG WM2277HSW XL Front Load Stackable...
The water will not drain out
Check on tips for finding if you have a blockage, or pump fault.The door will open if you can remove the water.I have tip posted. for checking this problem
Mar 05, 2010 | Washing Machines
My washer will go thru the cycles but wil not drain the wash water. sounds normal but will not **** out the wash water and therefore does not add the rinse water,
It is possible that something just got stuck somewhere in the drain hoses. I'd check for that first.
Also check that the belt is turning the pump properly (most likely it is), and only do so by hand with the washer unplugged.
If it is clear of obstructions you'll need to replace the water pump. part number AP4372886 (made by whirlpool)
Oct 29, 2009 | Maytag PAV2300 Top Load Washer
LG Model WD-80130F - Water not draining out
The pump is usually located under the unit, attached to the motor or belt driven. If not sure, it should have two 1 1/2 inch hoses attached to it. Something may be stuck in it or the bearings maybe wore out & it needs replaced. Pumps are not that expensive. Powder detergent will wear them out faster also!
Apr 15, 2008 | Washing Machines
Washing Machines Logo
254 people viewed this question
Top Washing Machines Experts
