Question about Merida AM 400-D
Hi I'd to change the original crankset and rear derailleur of my Merida AM400D (Shimano Deore) with the Shimano SLX. Any difficulties in doing so???? Thanks
    Brigadier General:
  • 8,546 Answers
The deralleur is cake but the crank may present problems not so much mechanically as in the 'q' factor or distance from the frame center to where the chainrings and pedals will rest. Sometimes when you change cranks you get a different effective depth of penetration by the bottom bracket so your chain lne may be difficult to adjust for good shifting.
I don't know an easy way to deteremine the end result prior to just trying it. A Bike Shop migh thave some data and recommendations for BB length.
This site gives a lot of good advice plus they sell the special tools you WILL require to remove the old cranks.
http://www.parktool.com/blog/repair-help
http://www.parktool.com/blog/repair-help/chain-line
Posted on Mar 14, 2011
Shimano fd-m510 front derailleur spring is stuck
Not a problem that can be diagnosed without eyes and hands on the bike. Post a clear video, or better - take to a bike shop or bike co-op.
Jun 12, 2017 | Mountain Shimano Deore Fdm510 Front...
I have a 2001 Specialized StumpJumper FSR XC and have put a new chain wheel on 48t and I'm struggling to find a front deriailleur that fits any help please?
Clamp on front mech xt or xtr would be an option, be careful if you need bottom pull or top, cut or grind off bracket on old front mech to reinstall,as this is a spacer as well as a mounting bracket ,bit old school but older front mechs are best
Jun 16, 2017 | Shimano Cycling
Shimano deore slx when i change down from 6 to 7 to 8 it hesitates or i have to go down 2 and back up 1? no problems when going up through the gears though
Go through theadjustments at some point but first determine if you have excessive friction in the cable. It is ON LYspring tension in the derailleur that makes it seek out to the smaller cogs. The cable just controls how far.
http://www.sheldonbrown.com/cables.html
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
What I was taught to do is shift to the highest gear, suspend the bike so you can access the rear derailleur and turn the crank by hand. It should go to the highest cog. If not, make sure there is no residual tension on the cable (or disconnect it from the derailleur completely) and pull the derailleur gently to see if it moves that last little bit. Keep rotating the crank. By repeatedly pushing the derailleur in to the largest cog and letting it spring back out to the smallest cog you can rapidly assess the limit screw adjustments to make sure it CAN reach each end gear without crashing the spokes or the frame with the chain. Reattach the cable and procede with the adjustments as prescribed in teh online resources.
Jul 16, 2011 | Scott Scale 70 Mountain Bike 2010
Hi Everyone! I have a Shimano 5603 Hollowtech 2 triple chainring.......(10 Speed) I want to add a Utlegra 6600 front derailleur and Ultegra 6600 rear derailleur. Also 10 speed cassette, Ultegra...
No -
If you are going to use the front triple crankset, then you need to use the 6603 components. These are for Triple set-ups.
If you intend to keep your bike a triple, then everything in the drivetrain must be the triple designation, hence the XX03.
If you want to change the crankset to a compact, then you can use the 6600 (double) equipment, but you will need to change the left (front shifter) to a double as well. The compact crankset, will give you virtually the same range as the triple and be much lighter and shift better.
The cassette: You can use any 10 spd cassette from Shimano or SRAM as long as the rear cog is no larger than 27. if you want to use a larger cog like a 28, then you will have to use the 6700 group, assuming yoiu want to stay with shimano ultegra.
Final Note: Since you are chainging everything, you may want to consider the SRAM Apex group, this gives you more gear ratio than the Ultegra, is slightly less expensive and around the same weight. Great alternative to Triple bikes.
Parts you will need to convert:
Rear Derailleur
Front Derailleur (if changing to compact double or Apex)
Chain
Shifter set (if Apex)
Crankset (if Apex or compact shimano)
Bottom Bracket (if Apex)
The biggest thing is that Shifters and rear derailleur must be from the same company (shimano, SRAM, etc.) after that just make sure that yoiu use 10spd with 10spd, 9 with 9, and so on. Everything else can mix and match.
Dec 18, 2010 | Shimano Ultegra Triple Front Derailleur Fd...
CAN I USE A 11-34 CRANCKSET IN A XTR REAR DERAILLEUR M972 SG?
11-34 referres to the cassette (rear gears) and it is perfectly suited to this gear range. 11T is the smallest and 34T is the largest it will handle.
The crankset referres to the front gears and I have not found a crankset that will not work with this derailleur
Nov 26, 2010 | Mountain Shimano Xtr Rd-m972-sgs Mtb...
Shimano Deore LX Chainring alignment
The large ring should be a no-brainer. There should be a nub on the outside surface that aligns with the crankarm to keep the chain from dropping between the crank and the arm.
The rings also have their tooth counts etched into them. They all line up.
Mar 29, 2010 | Shimano Deore LX Mountain Bike Front...
On a Shimano Deore LX rear axle, part of the thread is machined off. What is the advantage in this? ps, sorry this doesn't match the 'product' selected in the dropdown window - it was the closest option...
There is a washer on the hub that is not supposed to spin, so it has a "key" in it that matches the machined area of the axle.
Hope this answers your question,
matt
Oct 11, 2009 | Mountain Shimano Deore Fdm510 Front...
Unable to select bottom gear shimano 100gs
Here is a link to a tech sheet for a Shimano Deore rear derailleur. It is not your exact one, but all Shimano derailleurs are more or less the same. Make sure you have thoroughly cleaned your drivetrain with a degreaser (like Simple Green) and a brush to clear all grease and debris before making adjustments. The second step is to shift into your highest gear (the smalles cog) and then release the cable in the derailleur, pull taut and retighten it. Check again to make sure you can not get into low gear, because it may have been a problem with cable tension, which you just fixed. If it still does not, then adjust the "L" setting on the derailleur so that the jockey wheel on the derailleur will move just ever so slightly past the last cog on the cassette when the shifter is fully engaged.
Hope this helps,
matt
Oct 08, 2009 | Shimano Cycling
I have a Shimano Deore XT rear derailleur. At the moment it moves easily between the bigger cogs but doesn't move every time I change gear between the smaller cogs. For example, when moving from smallest...
The screws on the derailleur set the positional limits for the derailleur; if your description is accurate and it is always one position behind until the middle gears, I would guess it is not these screws causing the problem, but rather the cable tension is a little to low. There is a typically a knurled knob on the back of the derailleur that can adjust cable tension. Unscrewing it a little will tighten the cable. There may be other adjusters if you follow the cable up to the shifter. Try changing it in small increments (eg 1/8 to 1/4 turns) and go through shifts from high to low before determining if it is helping or not.
Jun 27, 2009 | Shimano Deore Xt Thumb Shifters 7...
Merida AM 400-D Logo
128 people viewed this question
Top Merida Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Merida Cycling Expert? Answer questions, earn points and help others
