Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 177 Answers
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Posted on Mar 14, 2011
  • mktk1310 Mar 14, 2011
    i mean, it's not the timer the power light normally goes green doesn't it when the tv is switched on.
    but after a little while the green light turn into red and back to green keep changing nd won't let me turn the tv back on .
  • Basuki Jrobenk
    Basuki Jrobenk Mar 14, 2011
    Which indicators are flashing (turned red and green) ? , did you hear friction sound from behind of TV set ?. Or have you reassembly rear cover properly. Check again conectors and switch in rear TV set. And check lamp fan, it can cause termal protection.
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Sony 50" new bulb but powers off after 1 minute?
if you was sure about lamp defective the you replace the lamp if was giving the same problem before .if not check lamp switch in side close to connection.one of the swith may be not making contact
Mar 01, 2012 | Sony KDF-E50A12U 50" LCD HDTV
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY BRAVIA 50IN KDF E50A12U
i have the same problem on mine, my tv is only just 12 months old, in the last 4 weeks it had 2 new blocks put in as the tv was blue, it costing £700 each (under guarante for 3 years thank god) then lastnight the tv made a big bang then switched it self off and the sand by botton is now flashing red then green, i have to leave it 30 mins before i switch it on again then only last 10 mins before it does the same thing again, got sony coming out again to day to fix it, had it with this tv now hate it !!!!!
Sep 01, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Televison & Video Logo
323 people viewed this question
Top Televison & Video Experts
Electro Med Services...
