Vacuums Logo
Posted on Mar 14, 2011
How to set an Omexey RT01B clock - Vacuums
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 14, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
378
Points
I cannot set my Omexey Clock - Model RT0168
1helpful
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 • Vacuums
My Seth Thomas radio controlled clock will not reset to the proper time. I've had it for many years, and this is the 1st problem. I changed the battery, I pushed the button for Pacific time ( I'm...
Hi lufberg,
I see you need help with your radio controlled clock.
Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1REo5s6T9
I hope this will help.
Thank you for choosing Fixya,
mvincentc
Jul 04, 2011 • Vacuums
I have a digital alarm clock from Next - it has the followin gfeatures a mode button - none of the options include time or hour etc an alarm on/off button a button with plus at the top and minus at...
Hi Karen,
Sounds like a neat clock!
I can't find anything about this clock. Other projection clocks set the time change automatically. What happens when you try to push the + button. Does it set the time ahead?
Also, what does it do when you press "kight"?
Karen, if I can't help you with this, please post again to let someone else have a try.
Please write back and let me know what happens with these buttons.
Good luck,
Handie Andie
Mar 27, 2011 • Vacuums
11helpful
How do I set a Omexey RT018B clock as I have lost the instruction book!
Press and hold the "Alarm set" button at the same taime as "DST Set" button this will then cause the year to start flashing
Adjust all settings with the + & - buttons (use "Alarm set to accept each option.
The time is the last in the sequence
I have an older model rca cd clock radio dual alarms. I cannot find my instructions for setting the clocks time. The batteries were dead when the electricity went off. Now the time keeps flashing the time.
For most clocks of the RCA clocks without a clock or time set button, press Set until you see the clock icon. Press the fwd or rev button to change the time. Release the button when you reach the correct time. (AM or PM will be indicated next to the time.)
There are manuals for several RCA cd clock radios available from their site: http://support.rcaaudiovideo.com/select.aspx?u=manual . Check if your specific model is listed in the menus.
I hope this helps.
Feb 03, 2011 • Vacuums
I dropped my battery operated alarm clock: the second hand still works but the alarm doesn't come on at the set time and the hour & minute hands don't "hold" their position - I took the clear...
The hour and minute hands can be pushed onto their respective shafts at any point in most clocks.
If you already know the time that the alarm is set, let the clock run until it sounds.
When the alarm sounds, install the hour hand and the minute hand to the exact alarm set time. If, say, the alarm is set for 6:30, push the hour hand onto it's shaft at exactly half way between 6 and 7 and then push the minute hand onto it's shaft pointing at exactly 6.
I think this should get you operating.
Gary
Jan 16, 2011 • Vacuums
I have a Sio/Scan Atomic Clock that gives time, indoor and outdoor temp. I have lost the instruction manuel and cannot set time or date since I changed batteries. CN5 V00 U Can you help me?
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
http://www.skyscaninfo.com/content/manuals.html
Jan 03, 2011 • Vacuums
3helpful
How do i set up my westclox 70034 outdoor thermometer to read on my clock unit.
Hi, First check the both channel of clock and thermometer (you can see the controler in battery insertion of thermometer and you can set up channel by pressing ch button on the clock)
Next press F/C search button until the clock find thermometer and press F/C search button again.
Oct 16, 2010 • Vacuums
I'm trying to find a manual for my weather genius EM3302A indoor/outdoor remote thermometer, purchased from XS Cargo. I need the manual to tell me how to change the clock from a 24 hour clock to the 12...
Weather Genius EM3302A Remote Weather Station
Once all settings are complete you press the UP button to toggle back and forth between the 24 hour clock and the 12 hour clock.
Sep 23, 2010 • Vacuums
19helpful
3answers
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 • Vacuums
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
