Question about Numark Industries Numark CDN 22 Mk4 Double DJ CD Player
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power off then power on. unit is only 5 weeks old.
  • Numark Master
  • 5,603 Answers
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Posted on Mar 14, 2011
I have a Gemini CFX-50 dual cd player. The left tray is not reading the cd whenever I put it in. I am getting a message "no disk". the right tray works fine. What could be the problem? Please help!
If the motor is spinning the disc, then your problem is with the laser. It either needs to be cleaned or replaced. Cleaning can be done with a regular laser lens cleaning disc, available at any store that sells electronics. A replacement lens assembly can be picked up at any store that specializes in electronics.
Oct 21, 2013 | Gemini Sound Products Gemini CFX 50 Dual...
My numark cd mix2 won't play a disc on the left hand side, it just says no disc
Hallo! This is caused by the laser fault. First unplug the cord, high voltage!!! Disassemble the device, look under the cd place you will see a little lense. Clean it VERY DELICATE with a piece of cottonwool with alcohol, can clean it twice with alcohol and then with a dry one. If doesn't help, then need to replace the laser reader system with a new one, it's that where the lense is placed, it must have on it an badge with the serial number, you can search it by that number/code.
May 18, 2011 | Numark CD Mix2
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
Keeps switching off and showing tocread on display
That probably means it can't read the "Table Of Contents" which is essentially the directory of the disc.
MAKE SURE any disc you try to read has been "finalized".
Any disc that you have burned that can have stuff added is NOT finalized and may not work in certain CD players.
May 08, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Oct 28, 2009 | Stanton C314 Tabletop CD and Mp3 Player
NO Disc
The first step is to clean the lens of the player using a cotton swab and alcohol. If that failes to resolve the problem, it is likely that the optics are starting to fail and need to be replaced.
Please clean the lens and update this with the results.
Thanks,
Dan
Aug 11, 2009 | Stanton C314 Tabletop CD and Mp3 Player
No disc displayed more often sometimes all the time
It sounds like you are having a laser problem. Either the lens is dirty and out of calibration or the laser is getting ready to go completely. In any case it will have to be serviced. You can try cleaning the lens yourself if you are comfortable doing it. It is like doing it on a game console or a regular cd player.
May 09, 2009 | Stanton C314 Tabletop CD and Mp3 Player
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
Numark Industries Numark CDN 22 Mk4 Double DJ CD Player Logo
175 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
