Question about Yahoo Messenger
Keep getting error pop up cannot load resorce DLL can you help
  • karen_chappl Mar 14, 2011
    Have tried that but it is satill happening
  • 604 Answers
Go to www.yahoo.com and find the download for yahoo messenger, download it and install on your computer, it should override the install you now have and fix the dll issure.
Posted on Mar 14, 2011
  • Keith Brown
    Keith Brown Mar 14, 2011
    ok then do a google search for yahoo messenger DLL file and see if you can locate it that way. It may be a part of the windows operating system, have you tried using any other messenger type service, like Live Messenger? if it does the same thing it would indicate a operating system error, if it does work then is a yahoo messeger only issue.
Clkern.dll was loaded,but the dll register server entry point was not found.this file can not be registered
http://www.fix-all-dll-errors.com/clkern.dll/
Once you go to the above link click "Fix dll errors now" button,
it will register the dll file for you.
Dec 29, 2010 | Car Audio & Video
Error loading zsqiupzq.dll
Go to Run-->msconfig then see under Startup Uncheck the file showing zsqiupzq.dll file..
**Don't forget to rate and give a positive testemonial...If you find my solution helpful**
Have a Nice Day
Oct 10, 2010 | Microsoft Windows XP Professional SP2
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
A pop window occurred as page load error 502
Hello
Thank you for using
FixYa for your problem
go to start / then go to RUN and there copy the following( all together 1 space Between words)
regsvr32 softpub.dll initpki.dll wintrust.dll
Then Click OK to all 3 pop-up small windows-
if any fail write me apart.
if all 3 succeed then go back to RUN and type CMD a black DOS screen will pop up, type there as follow
netsh winsock reset log.tx.
then hit enter and read what its says and do as he tells you
good luck!
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Microsoft Computers & Internet
RUNDLL
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll
Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below:
1. Open your Start menu.
2. Click Run
3. In the command screen type:services.msc
4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service.
5.Stop the "dll"service immediately.
STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start
2. Click Run
3. Type regedit
4. Find this registry key:
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]"
6. Delete the value and Restart.
May 01, 2009 | Computers & Internet
In start up RunnDLL pops up saying ERROR (please help)
this problem is due to missing of dll file from your system, click on Start> Run, type msconfig> tab startup from top and find out the file name above which you just mention and uncheck it now click apply and Ok after restart you will get some messege check mark on it.
Mar 29, 2009 | Microsoft Computers & Internet
Laptop
Have them put the Windows CD in, and run sfc /scannow.
If that doesn't fix it, time to do a wipe and reload.  don't mess around with viruses or spyware any more, just reinstall win..
Oct 17, 2008 | HP Compaq Presario v3000z Notebook
M3plugin.dll
You have left over pieces of a spyware and/or adware program. Here is how to go about removing them:
1) Goto 'Control Panel' then to 'Add/Remove Programs'
2) Locate 'My Web Search' Select 'Change/Remove' and uninstall it.
3) Also look around for other programs associated 'FunWebProducts' like:
My Web Search
My Speedbar
Search Assistant - My Way
4) Once you have cleared the out of your program's list, proceed to your C drive.
5) Goto Program Files
6) Locate and delete the following folders;
FunWebProducts
MyWebSearch
7) Finally Goto Start>Run
8) Type 'msconfig' and press OK.
9) Once the msconfig window pops up select the Tab labeled "Startup"
10) Sift through the startup items look for anything pertaining to either FunWebProducts and/or My Web Search
11) Once found uncheck all of them(FWP/MWS items).
This should fix your start up issues. I would also advise you to Get Spybot-Search&Destroy From here. This will keep you from getting nasty programs like this again.
Hope that helps. If you have any questions lemme know.
Sep 16, 2008 | HP Pavilion dv6000z Notebook
M3PLUGIN.DLL
Error loading
C:\PROGRA~1\MYWEBS~1\BAR\1.bin\M3PLUGIN.DLL
The specific module could not be found.
please solf this problem
Jul 16, 2008 | Intel Motherboard
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
