SOURCE: Creative Zen Vision m
Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
SOURCE: creative lab zen sleek photo
Try rebooting the player. This is how u do that. Press and hold the play/pause button. then use a paper clip and push it into the little hole on the bottom of the player next to the charging port. pull the paper clip out and the diagnostic screen should appear on the screen of the player. release the play/pause button. scroll down to reboot and touch the touch pad to reboot. hope that helps.
SOURCE: Creative Zen V Plus, it charges, but I can't transfer audios.
ok... i found a fix...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on device manager
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
SOURCE: my creative zen screen was flickering white
SEEMINGLY RANDOM PROBLEM
I've seen a million reasons why people think their Creative Zens are going to the white screen of death. I've tried a million different things myself in trying to 'solve' the problem. The only quick-fix that has worked consistently was freezing the Zen (in a plastic bag, of course). After freezing it, it always boots fully the first time I turn it on, but your guess is as good as mine as to how many times it will work before having to freeze it again.
PUT THE SQUEEZE ON - CAREFULLY!
To me, the problem has always seemed like it had to do with a lack of connection or contact inside the thing. So, my next theory has proved - so far - to work even better than freezing. However, it's a bit of a risk to the LCD screen. I noticed the casing seemed a bit "loose", so I squeeze it (be careful not to break the LCD!!!!) as I turned it on. The first time I did this was last night. The Zen has properly booted every time I've turned it on since then. I've left it for hours and turned it on occasionally when I've thought of it...and presto!
I ASKED AN EXPERT!
My brother is an electronics expert. I described the problem to him and asked his opinion. Without going into detail (that I can't remember anyway), he concluded that there are contacts in the casing for the LCD that just aren't quite making the contact.
WHY?!
I fail to understand why Creative refuses to do anything about this problem when it seems that it would be a simple fix. I understand that they have more lucrative business to attend to, but selling a bum product and not even acknowledging the problem - much less fixing it - just isn't right.
SOURCE: ZEN will not power up
First back up all of your music and do this: Turn off the player and make sure it is disconnected from the computer. Then press and hold the play/pause button and turn it on simultaneously. It will then enter recovery mode. Scroll down and select format (all) and let it format and it should work like normal. If it freezes again, then you may need a firmware update.
