Question about Dishwashers
Nothing wrong with dishwasher just need top basket weel and clips to go on upper basket runner to stop from falling out, all our have broken
  • Anonymous Mar 23, 2014
    End runner cap broken need diagram of how to refit the upper basket
  • Dishwashers Master
  • 3,247 Answers
Can try to find the correct wheel and clips if you can provide the make and model of the dishwasher
Posted on Mar 14, 2011
Problem fitting top basket runners
To move to the higher position proceed as
follows:
1. Move the front runner stops (A) of the upper basket
outwards and slide the basket out.
2. Refit the basket in the higher position and replace the stops
(A) in their original position.
Dado
Aug 09, 2015 | Zanussi Dishwashers
Electrolux dishwasher wont lock but still runs, water sprays out of the door
check that the top basket wheels are not broken a rogue wheel in the runner can stop you pushing the top basket in. this stops you closing the door. also that the retainers on the end of the runners are in the right position and not jamming the door action. failing that you will need a new door lock..
Jul 30, 2010 | Electrolux Dishwashers
The slide on the upper basket keeps falling out. It's been fixed twice but doesn't hold. The second repair man who put the slide back in the rollers said he couldn't see anything wrong with it, but it...
One option is installing stainless steel washers on the rack supports that screw into the side of the tub. The rack falls down because there is too much "slop" with the rack...a couple small washers to space them tighter normally does the trick.
Mar 30, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Hi- my dishwasher - single drawer fisher and paykel seems to be stuck on runners- will not open smoothly
this could be a broken wheel or something jamed inside the runner, theres a little plastic clip that is on the end of each runner remove the clips and pull the basket all the way out then check for broken wheels or something jaming it, or even a twisted runner. be carefull removing the clips as they can snap. Ps carefull of sharp edges too.
Jan 20, 2010 | Dishwashers
Top rack will not pull out all the way
Replace the upper basket wheels - these are available as spares. If the metal runners look angled - it may be the wheels on the side of the dishwasher that need replacing. These are also available as a spare part.
Ebay is actually a good place to shop for spares of this type.
Aug 04, 2009 | Asko 24 in. 1585 Built-in Dishwasher
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
Top rack slider
All I can think of is that the runners on the rack are not in the runner slide on the machine properly or there is an obstuction (EG:loose screw)in the runner on the machine side
Jan 22, 2009 | GE Adora GHDA656LSS Stainless Steel...
Top rack is not level. Glasses and cups roll forward
I assume that the bottom rack is level and the upper rack is not.
On the LG dishwashers, you can remove the upper rack by removing the little gray clip at the front of the rails. Each will fall off in your hands. You can then pull the basket out.
Place it on the floor and confirm that all wheels roll properly and all touch evenly. Resolve any problems on the rack via LG service parts.
Inspect the rails still inside the dishwasher, confirm that they are paralel and level.
Replace the upper basket carefully, making sure the wheels all slide into the rail evenly.
Please update me on what was done to finally resolve the problem.
Oct 12, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Broken Plastic Squares
Yhey come from the upper rack bearing kit. You will find more plastic and then the bearings will fall out. It is a $30 fix. Part #1394379
Jul 01, 2008 | Asko 1385 Dishwasher
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
