Question about Garden
What happened to my request for the proceedure to follow in changing a clutch in a sthil 18 inch chainsaw? you've charged me $6 and i've read your return email once and then it disappeared off my computer in less than 24 hours. Is your set up some form of scam or what? A more definative answer would be appreciated. Rgds. Phil
  • 95 Answers
I have no idea who you talk to before?But i will try and help.You need to remove the side cover and bar.The clutch unscrews counter clockwise.You can use a something like a punch and hammer.Give it a quick hit and it should come loose.Put it back on the same way.Just give it a couple hits to tighten.If the teeth on the clutch cover are very worn replace that also.Anything else I can help with just send me a email.They usually come off fairley easy.
Posted on Mar 14, 2011
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
What causes the Clutch drum gear that drive the chain to go bad ? my chain eats a groove all the way through it aftr about 12 hrs of cutting I have replaced it 3 times now.
The chain you should be using should be a .325 pitch and not a 3/8.
Never over tighten the chain, it will wear and stretch with time, which is why you should regularly check the chain tension. To get it right you should be able to lift 2 drive links clear of the bar. The chain will naturally wear groves into the spur sprocket, there is no conversion to a rim spricket for this model. Rim sprockets allow the chain to move along the sprocket easier and takes the wear away form the clutch drum.
Oct 11, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
I have a Craftsman 18"
I lost you but you do need a special tool for the clutch removal.Sorry I lost you.........Darryel (dleemacc)
Jul 31, 2011 | Craftsman 38cc 16" Gas Chain Saw
Removal directions for the clutch for husqvarna257
It is a left hand thread, so to remove turn it clockwise as you look at it.
Apr 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Change drive spocket
To change the sprocket you need to remove the cover where the bar attaches, remove bar and chain...then you will need to unscrew the bolt on the bell. the bell should slide off...check to see that the new clutch bell comes with bearings, as you may need to purchase separately...then reassemble in reverse order...note: make sure that the brake is NOT engaged when you take the cover off as it will make it difficult to put the cover back...and trying to release the brake with the cover off is VERY difficult
Jan 18, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Saw won't start
If you have followed all of the manual instructions for starting, take the machine back to the selling dealer and have them start it. If it runs for them, obtain whatever clues you can from their procedures. If they can't get it to run either, request a replacement unit. Good luck!
Dec 03, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Sthil are a roal panin in the *** takes 50 time of pulling the rope to get it started
Read you manual. you will NEVER have to pull anything 50 times to start it... pull off your muffler (if you filled it with gas) and let it dry out.
READ YOUR MANUAL
Mar 09, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Echo chainsaw clutch cs 370
the nut is part of the clutch bell housing just spin the bell counter clockwise and hold the flywheel or you can buy a tool that goes in spark plug hole its called a "dead stop"
Jun 06, 2009 | Poulan Pro Chain Saw 46cc 20"
My 18 V ryobi chain saw doesn't activate
Batteries need to be stored fully charged and recharged every month or so while in storage. Batteries need to be kept cool. Try another battery to see if the battery is bad or if the saw is out of order. Contact Ryobi @ 800 -525-2579 The full extent of your message did not appear on my screen. So I am not sure this helped you.
Jan 22, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
