Question about Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer
Hi. All lights are flashing I pressStar 2864 and head volt shows
Unable to clean50 brother mfc-j220
You need to do the following. Enter maintenance mode by pressing Menu * 2864 in less than 2 seconds. Press Stop and retry if you dont see the lights blinking. Then press, 80, 2864, 4460, 99. It should work, otherwise its a fault service station pump
Jan 07, 2015 | Brother MFC J220 Multifunction Printer
Electrical Problems
What make and model car is this?
Jun 05, 2014 | 1999 Chevrolet K1500
I have a brother MFC665CW getting an error code --- unable to print 51
Hi Ok try this it may work.
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
Code WSW51 0000001 will show
Try different values, eg change to 000000 or 0000010
BUT remember original code to get back to
To exit type 99
Also can try.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one
All The Best: Pineworks
Oct 10, 2009 | Brother MFC-665CW All-In-One InkJet...
I have an Error 51 on my brother MFC 5460 USB printer.
Hi There
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
Jun 09, 2009 | Brother MFC-5460CN All-In-One InkJet...
Lcd reads machine error 41 ,it started with cannot initiat i pressed menu/set and *2864 within 2 secs then error 41 came up
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
Apr 15, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother mfc 240c error says print unable 51
Hapens a lot
1.Go Menu
Type in *2864
Type in 10
Code WSW00 shows
Type in 51
To exit type 99
Also can try.
Solution:
· Machine off
· Press 80
Feb 24, 2009 | Brother Multi-Function Center MFC-240C...
1998 Chrysler T&C Charging problem
voltage regulator is broken (alternator) change it our gonna fry another battery symtom head light flash dont drive like that change the alternator hope it a fixya thanks pierre
Jul 31, 2008 | 1998 Chrysler Town & Country
Brother MFC-5840CN
Press Menu, * 2864. That puts in in maintenance mode. If it flashes error 48, the flat ribbon to your head is broken. You'll need to replace the entire head assembly. Press 99 to leave the maintenance mode.
Jul 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
UNABLE TO INIT
MENU * 2864 VERY QUICKLY TAKES YOU TO MAINTANENCE MODE, ALL LIGHS FLASH... PRESS 82 SET, YOUR ERROR CODE WILL DISPLAY. THAT IS NEXT STEP.!!!!
Nov 16, 2007 | Brother MFC-5840CN All-In-One InkJet...
Metz 6ct4 flash head
Are you still having problem with the flash not flashing? Use a DVM (digital volt meter) to measure the battery from the pack. Take the 6 volt battery out from the pack and measure it. A reading of 6vdc or greater is good. Also the for amp. of the battery. Alexander atdlee@netzero.com
Apr 05, 2007 | Metz Mecablitz 60CT4 TTL Flash
Brother MFC-425CN Multi-Function Center All-In-One InkJet Printer Logo
27 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
