My printer slow in on position always have error on cartridge.help me solve this one
    Problem Solver:
  • 12 Answers
First you check you have installed its driver properly..
Posted on Mar 14, 2011
HP officejet error code 0x6101beb
If you get the Error code 0x6101beb on your printer, it's one of the common error occurs in Printer. In case this error is not fixed, it may lead your system slow or even it will crash the whole printer. Fixing the error code 0x6101beb manually is a difficult process so we suggest you can use any troubleshooting tools. In Some times, remove the cartridge from the printer and reinstall it, this will clear the error messages from your printer. Follow the given steps for troubleshooting the error code 0x6101beb,
1. Power on the printer and open the cartridge access door.
2.
If the cartridge comes the position, power off the printer and disconnect the cables.
3.
Remove the ink cartridge from the printer and leave it for 60 seconds.
4.
Then again insert the ink cartridge in their respective slots.
5.
Power it on and check if it clears the error.
Still, the error persists on your printer, better you can contact the printer experts through the toll-free number 1-800-386-3987 or 123.hp.com/oj4650.
Jan 20, 2012 | Office Equipment & Supplies
I just installed new refilled printer cartridges #27 and #17 and I am getting a missing cartridge at the color side. Please help me to solve this problem. Thank you so much.
Make sure you are inserting only genuine Lexmark cartridges.
Please follow the steps below to fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove the color cartridge from the carrier.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert the color cartridge.
7. Close the printer cover and check for any errors.
If error re-appears, try to insert a different known working cartridge to determine if the other is faulty. Or better yet, replace your color cartridge with a new one.
Jul 27, 2011 | Lexmark X1240 All-In-One InkJet Printer
Error: 0xc19a0021 Ink system failure Any suggestions?
These errors that always come out starting with 0xc.. - only means that there are internal error inside the printer.
These errors can only be remove if you reset the printer.
here's the step to reset your printer
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
Hope that solve your problem..
Much appreciated if you rate this help..thanks..
May 24, 2010 | HP Photosmart C5180 All-In-One InkJet...
When i start printer E 7 2 error messge is displaying
Probably It show 2 (two) kinds of signal or error message.E2 or E7.
just problem E2 mean no insert recording paper.
Problem solve: when show this error press color key or black key then try to feed paper this printer.
E7: when show E7 some fine cartridge are not install properly right position.
Problem solve: follow mark where install color and black cartridge.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon MP210 gives E9 error. How does it solve?
Some of the error codes for your printer,
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
hope it helps
Jun 11, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My brand new printer is displaying printer error code 5100 and will not print or recognise the ink not sure if this means the ink cartridges are faulty.
That error translates as a "Carriage error"... which means that the printer carriage (the bit that holds the cartridges) is unable to move or similar.
Check you've installed the cartridges correctly and that the grey lever that holds down the printhead, etc.. has been put in the down and locked position.
You may find that you've installed the printhead incorrectly so worth pulling out the cartridges, removing the printhead and then reseating it so the lever goes down to a horizontal position. Then reinsert the cartridges.
If that doesn't solve it the best course of action is to return it and demand a replacement.
Feb 19, 2009 | Canon Pixma MP480 All-In-One InkJet...
Lexmark error: 33.64
Change Toner cartridge.
Do not refill your toner cartridge in the same place anymore ;) Do not refill them like 10 times ;) Use original toners for your MF/Printer
Maxi
Feb 18, 2009 | Lexmark All-in-One Printer with PictBridge
Check Printer Cartrige
my printer is
HP PSC 1410 ALL IN ONE PRINTER
ERROR MESSAGE
1. CHECK PRINT CARTRIDGES
I AM REMOVE THE OLD CARTRIDGES
THEN NEW ADDED 21,22 CARTRIDGES
THEN NEXT ERROR MESSAGE
HOW TO SOLVE THE PROBLEMS
Jul 09, 2008 | HP PSC 1410 All-In-One InkJet Printer
Right cartridge incorrect for Lexmark X3350
checked the Lexmark knowledge base for the error message "right cartridge incorrect". It came back with instructions for the X8310/8350, X7350 and X7170. Nothing for the X3350.
http://www.lexmark.com/uncomplicate/chan...
The instructions seem to be pretty much the same for all other models so maybe they'd work for your 3350. If not, there's always the technical support link. I've got an older X1150 and tech support has always helped me out
Feb 22, 2008 | Lexmark OfficeCenter X3350 All-in-One...
11 people viewed this question
k24674
jasbo
jasbo
