Question about Gateway M-6750 Notebook
The backlight on my gateway m 6750 is out. i think it is the lidswitch but can't find it. can someone tell me where the switch is located on my laptop.thanks
  • 1,719 Answers
The LCD screen displays is dark/ dim (faint display that can be seen in sunlight or torchlight) because there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both. But most likely it is the CCFL (Lamp). Its life is limited and depending upon how long it has been in use, you can have a better idea - if its the CCFL or Inverter.
(You can check it by connecting you PC with some external display, which would work fine). (Hence, the board/ graphics processor is OK. In case the graphics processor fails, there is no display at all on the external monitor).
The LCD display switch in inside the modern laptop and its function is that it completely shuts down the display (no light as well as image).
So, my advice is that you check the LCD display for replacement of CCFL. I have found a general link about CCFL replacement. Click here for detailed and graphical DIY instructions about LCD disassembly.
Make sure you take proper precaution while working inside LCD, as the inverter generates a very high voltage.
IF YOU ARE NOT EXPERIENCED WITH WORKING INSIDE SUCH ELECTRONIC COMPONENTS, I SUGGEST THAT YOU SEEK PROFESSIONAL ASSISTANCE FROM AUTHORISED SERVICE/ REPAIR CENTER FOR REPLACEMENT OF CCFL OR INVERTER.
Hope it helps! Good Luck!
CreativeTECH
Posted on Mar 14, 2011
Gateway m 6750 drivers xp sp3
go to http://support.gateway.com/us/en/product/default.aspx?partNumber=1015078R
Apr 30, 2012 | Gateway M-6750 PC Notebook
Does anyone know how to replace the CMOS Battery on a Gateway M-6750 Laptop?
instructions for dissassembling Gateway laptop in this link, not my work another persons
http://www.ehow.com/how_4840438_apart-gateway-laptop.html
then when you have the cmos battery in site it will be a case of unclipping from battery holder and replacing
Oct 06, 2011 | Gateway M-6750 Notebook
My Gateway M 6750 Laptop powers on goes into bios with no problem but when you first turn it on it shows the gateway sign then it goes blank but the screen is still lit up
It is possible there is what is called a "root kit" virus on this system. You may have to take it into a computer shop. Alternatively, if you are a computer guru; insert the cd for the operating system. On the 6750 ; that comes with Windows XP. Go to the "recovery console" and then issue the command "Fixbook /mbr" which will rewrite the boot record; and solve the problem. Hope that helps, and best of luck.
Jan 29, 2011 | Gateway M-6750 PC Notebook
I'm getting the blue screen indicating that the hard disk is going to fail on my Gateway m 6750 laptop. I backed up all of the information, but when I try to reload the operating system, I get a message...
My best guess is you need a new hard drive.There are some decent prices on E bay and Amazon for new HD's. Even you you manage to format your old HD and reinstall your Data from my experience you will be very lucky if even lasts a day.
Oct 23, 2017 | Gateway M-6750 Notebook
Gateway m-6750 power light and wireless light flashing
Try logging in in safe mode.
Try entering the BIOS and resetting to default values.
Try booting up from your CD drive
Aug 26, 2009 | Gateway M-6750 PC Notebook
Gateway 6750 not powering up. I have a good power
If it sounds like it is turning on for about a second and lights up then it might be the motherboard. Also the screen will stay black, but the lights will turn on.
Jun 25, 2009 | Gateway M-6750 Notebook
Gateway M-6750 Motherboard Power Short, Little Clips
Had the same issue. Clip fell off, moved around, hit the motherboard and it fried. I hope there is a class action lawsuit against gateway
Replacement motherboard $400, new Lappy $600.
Jun 09, 2009 | Gateway M-6750 Notebook
Gateway m-6750 no sound
Go to the volume settings and make sure the mute switch is turned off.
Mar 20, 2009 | Gateway M-6750 Notebook
My whirlpool thin twin filled with water and stopped!:(
Well if it fills then it needs the lid shut to work. So if the lid is shut it hits a lidswitch and if that lid switch is broken then nothing will work washer wise right? As far as the dryer that may be a blown fuse but nothing on the washer could stop it from running cept maybe a bad cord or breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 28, 2008 | Whirlpool LTE5243D Top Load Stacked...
Gateway M-6750 Notebook Logo
158 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
