The tray will not open,have tried to pull it open,but get message saying,"tray error"
    Problem Solver:
  • 12 Answers
In this case your cd player is absolutely ok just motor of tray has damaged just open your cd player and replace dc motor you can buy it from any electronics equipment shop..just read the specification which is written on motor and then buy it...
Posted on Mar 14, 2011
Printer notes "Error 6000". It is being used
Take a close look at the printer and the paper tray. The error usually means that the paper output tray is closed (or something is blocking it from opening). Remove the object blocking the paper tray and pull it fully open (including the extension). Then turn off the printer and turn it back on. The error can also occur when a book is being scanned that blocks the paper tray.
Some documentation on the Canon error messages for the MX860 is here: https://www.canon.ie/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MX_series/PIXMA_MX860.aspx?faqtcmuri=tcm:24-644260&page=1&type=faq .
I hope this helps.
Sep 11, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
I am trying to open "Backyard Soccer 2004." I tried to open the website in the troubleshooting read-me. The link was http://www.ina-support.com. That took me to http://www.atari.com/. Anyway when...
If you have the game disk, put it into your CD tray. Use the Disk to re-install the game to fix any errors. Most games that have this feature will ask if you would like to save your game files, and will prevent you from losing any of your saved games or settings. The game will prompt you to install the game, or play it. Click the install option and it will ask if you want to repair it, or clean install. Click repair if the option is there, if not, then run a clean install and that should fix your issue
Jun 26, 2011 | Infogrames Backyard Soccer 2004 for...
Hi...I have a problem with my HP Photosmart C7280...can you help ? the error message "Photo tray problem" keeps coming up, telling me to "lift the output tray, push the photo tray all the...
Photo tray problem
' Lift the output tray up and verify that the photo tray
' is pushed in until it stops, then lower output all the
' way down. Press OK button on the printer to
'continue printing
HP Photosmart C7280 All-in-One Printer
1. Turn off printer.
2. Pull out paper tray and photo tray
3. Remove output duplexer (on back of printer)
4. Open input sheet feeder (on top of printer)
5. Open cartridge access door. (Basically lift up control panel and scanner section of the printer)
6. Turn on printer (Power button on now raised control panel)
7. Printer may display message "Performing printer alignment - Do not interrupt"
8. Wait for a few minutes until printer stops making all setup noises.
9. Close cartridge access door, close input sheet feeder, replace output duplexer, insert paper trays
10. Do a test print. All should be fine.
Mar 11, 2011 | Office Equipment & Supplies
Tray for cd won't open and it says "mechaical error." Unlike in the past there seems to be nothing stuck or askew inside. I left unit on overnight and tray was apparently open because I saw it...
you need to open the cover of your component and have access to the mechanical system of the CD. The timing gears might got dislocated and you need to manually adjust them.check also if there are belts that are broken replace them.
Mar 07, 2011 | Yamaha GX-505 CD Shelf System
I turn my 360 on and instead of reading the game, it says "open tray". i open the tray and close it back and i hear 2 clicks and then it says "open tray" again.
My Xbox 360 does that too sometimes. All I usually do is first try turning the disc. If that doesn't work, try an empty tray. If you still get that message after trying again, put in a DVD. That can help. If none of that works, unplug your 360 and leave it for a day. Then try again.
Please rate my answer if it helps.
Feb 18, 2011 | Microsoft Xbox 360 Console
Printer says "error on paper tray". The paper is
Are you getting a specific error message or error code?
Jan 03, 2011 | Canon SELPHY CP740 InkJet Photo Printer
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
94 people viewed this question
 Grubhead
Grubhead
