How and where to plug all wiring to - Audio Players & Recorders
  • 604 Answers
You don't say what components you have so its hard to tell you exaclty what to do, so I'll guess. first: if you have a DVD player, plug the yellow rca cable into the "video in" on your tv. take the red and white (or red and black) cable and plug that into the same color jacks on your amplifier/receiver, this might be called "input one" or something like that. you should now have sound from your DVD player coming out of your reciever/amplifier. If you have other componets, they should plug in the same way. a cassetter player for instance would have the red and white ( or red and black) rca type outpurts, plug that into the same color on your reciever/amplifer, only this time choose the next input available (eg. input 2) let me know what type of amp you have and what your are trying to plug in, so I can give you better instructions.
Posted on Mar 14, 2011
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
How do i remove a stuck spark plug wire on a 2003 pontiac grand prix
You will have to replace the wire. Pull old one off remove spark plug pry the metal end of the wire off the spark plug. Replace spark plug install new wire. there is anti stick for spark plug wiring I would use if I was you
Aug 07, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Change spark plugs
  1. Disconnect the spark plug wire at each spark plug.
    • Twist each spark plug 1/2 turn.
    • Pull only on the boot in order to remove the wire from each spark plug.
  1. Disconnect the spark plug wire from the ignition coil.
    • Twist each spark plug boot 1/2 turn.
    • Pull only on the boot in order to remove the wires from the ignition coil
  • Install the spark plug wires at the ignition coil.
  • Install the spark plug wire to each spark plug.
  • Inspect the wires for proper installation:
  • Repeat above procedure for all 8 cylinders.
  • Jun 17, 2013 | 2003 Hummer H2
    How to remove wires from sparkplugs of a guick lucerne
    USE A SPARK PLUG WIRES BOOT PULLER.THE BOOT PULLER CAN GO TIGHT PLACES WHERE YOUR HANDS CANT REACH.ONCE YOU REMOVE SPARK PLUGS WIRES REPLACE THEM.SOME PLUG WIRES WILL BREAK AWAY FROM THE BOOT WHEN REMOVING SPARK PLUGS WIRES.DONT REMOVE OLD PLUG WIRES IF YOU DONT HAVE NEW SET PLUG WIRES ON HAND.BECAUSE YOU WILL DISABLE VECHICLE.IF COUPLE OLD PLUGS WIRES BREAK WHILE REMOVING THEM YOU WILL BE 2 PLUG WIRES SHORT AND YOU CANT DRIVE VECHICLE THAT WHY HAVE NEW SET OF PLUG WIRES ON HAND.
    May 12, 2011 | Buick Lucerne Cars & Trucks
    2001 dodge ram 1500 5.2 v8 van spark plug diagram
    firing order is 1 8 4 3 6 5 7 2 standing in front of truck. cylinders on passenger side facing you are 2 4 6 8 cylinders on driver side facing you are 1 3 5 7 now this is your spark plugs wires location on distributor cap.with distributor facing you.2 plugs wire on cap 6 oclock position 1 plug wire on cap 8 oclock position,8 plug wire on cap 9 oclock position,4plug wire cap 10 oclock position,3 plug wire on cap 12 oclock position,6 plug wire on cap 1 oclock position, 5 plug wire on cap 3 oclock position, and 7 plug wire on cap 5 oclock position. in order for this to work you must be standing facing the engine all plug wire location on cap should be correct.
    Apr 08, 2011 | Dodge Ram 1500 Cars & Trucks
    Describe your how fix my pontiac 2000 montana Problem changing spark plugs
    Inspection
    Inspect for the correct routing of the spark plug wires. Improper routing may cause cross-firing. Inspect each wire for any signs of cranks or splits in the wire. Inspect each plug wire boot for tearing, piercing, arcing, carbon tracking or a corroded terminal.
    If there is any corrosion, carbon tracking or arcing indicated on a plug wire boot or terminal, both the plug wire and component it was connected to should be replaced.
    Removal & Installation
    3.5L Engine
    1. Before servicing the vehicle, refer to the Precautions Section.
    2. Remove the left side spark plug wires from the spark plugs.
    3. Remove the left side plug wires from the retaining clips.
    4. Rotate the engine for access as follows:
      1. Set the parking brake.
      2. Shift the transaxle into neutral.
      3. Remove the engine mount strut bolts. Swing the engine mount struts aside.
      4. Install the Engine Tilt Strap J-41131.
      5. Pull on the engine in order to rotate the engine forward.
      6. Tighten the strap.
    5. Remove the right side spark plug wires from the spark plugs.
    6. Remove the plug wires from the retaining clip.
    7. Remove the spark wires from the ignition coils.
    8. Remove the plug wire assembly from the engine.
      NOTE If you are replacing the spark plug wires, the spark plug wire conduit and retaining clips should be transferred to the replacement wires.
    To install:
    1. Install the right side plug wires to the ignition coils and then the spark plugs.
    2. Install the spark plug wires to the retaining clip.
    3. Rotate the engine back to the original position.
    4. Install the left side spark plug wires to the ignition coils and then to the spark plugs.
    5. Install the spark plug wires to the retaining clips.
    3.9L Engine
    2. Remove the intake manifold cover.
    3. Remove the left side spark plug wires as follows:
      1. Disconnect the left side spark plug wires from the spark plugs.
      2. Disconnect the left side spark plug wires from the ignition coil.
      3. Remove the left side spark plug wire clips from the intake manifold and heater inlet and outlet pipe.
      4. Remove the left side spark plug wire assembly.
    4. If removing the right side spark plug wires, the engine must be rotated for access as follows:
    5. After rotating the engine, remove the right side spark plug wires as follows:
      1. Disconnect the right side spark plug wires from the spark plugs and ignition coil.
    6. Remove the right side spark plug wire clip from the ignition coil bracket.
    7. Remove the right side spark plug wire assembly.
    To install:
    1. Install the spark plug wire assembly.
    2. Install the right side spark plug wire clip at the ignition coil bracket.
    3. Connect the plug wires to the ignition coil and spark plugs.
    4. If the engine was rotated for access, return the engine to the original position.
    5. The remainder of the installation is the reverse order of removal.
    Feb 05, 2011 | 2000 Pontiac Montana
    Anyone have the 2001 VW Golf speaker wire colors?
    If your Golf is the premium sound model here is the list:
    2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
    Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
    Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
    Car Radio Ground Wire: Plug #3, Pin #8
    Car Radio Illumination Wire: Plug #3, Pin #6
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: N/A
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Plug #2, Pin #5
    Left Front Speaker Negative Wire (-): Plug #2, Pin #6
    Right Front Speaker Positive Wire (+): Plug #2, Pin #3
    Right Front Speaker Negative Wire (-): Plug #2, Pin #4
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
    Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
    Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
    Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
    Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
    Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
    Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
    CD Changer Data In Wire: Plug #1, Pin #13
    CD Changer Data Out Wire: Plug #1, Pin #14
    CD Changer Clock Wire: Plug #1, Pin #15
    CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
    CD Changer Control Signal Wire: Plug #1, Pin #17
    CD Changer Ground Wire: Plug #1, Pin #18
    CD Changer Left Line Out Wire: Plug #1, Pin #19
    CD Changer Right Line Out Wire: Plug #1, Pin #20
    May 18, 2010 | Car Audio & Video
    I need the diagram to put the spark plug cables
    2003 Chevrolet Malibu 3.1L SFI OHV 6cyl
    Spark Plug Wires - Removal & Installation
    3.5L Engine
      NOTE Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
    2. Remove the intake manifold cover, if required.
    3. Disconnect the left side spark plug wires from the spark plugs.
    4. Disconnect the left side spark plug wires from the ignition coil.
    5. Remove the spark plug wire clips from the Manifold Absolute Pressure (MAP) sensor bracket and the heater inlet and outlet pipe tab.
    6. Remove the spark plug wire assembly.
    7. If replacing only one plug wire, open the retaining clips and remove the appropriate spark plug wire.
    8. Disconnect the right side spark plug wires from the spark plugs.
    9. Disconnect the right side spark plugs from the ignition coils.
    10. Remove the spark plug wire assembly.
    11. If replacing only one plug wire, open the retaining clip and remove the appropriate spark plug wire.
    To install:
    2. Connect the right side spark plugs to the ignition coils.
    3. Connect the right side spark plug wires to the spark plugs.
    4. If replacing only one plug wire, open the retaining clip and install the appropriate spark plug wire.
    5. Install the spark plug wire assembly.
    6. Connect the left side spark plug wires to the spark plugs.
    7. Connect the left side spark plug wires to the ignition coil.
    8. Install the spark plug wire clips to the MAP sensor bracket and the heater inlet and outlet pipe tab.
    9. If replacing only one plug wire, open the retaining clips and install the appropriate spark plug wire.
    10. Install the intake manifold cover, if required.
    Fig. 2.2L Engine Firing Order: 1-3-4-2 Distributorless ignition system
    Fig. 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
    Fig. 3.5L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
    Fig. 2.4L Engine Firing order: 1-3-4-2 Distributorless ignition system
    Fig. 3.5L & 3.9L Engines Firing order: 1-2-3-4-5-6 Distributorless ignition system
    I really hope help you with this (remember rated this help) Good luck.
    Sep 23, 2009 | 2003 Chevrolet Malibu
    Change my spark plug and wires now my car is running rough
    Check to make sure you have not cross the wires and your firing order is off by one wire.
    http://autorepair.about.com/library/firing_orders/bl-fo-8792.htm
    Good luck and hope this helps.
    Sep 16, 2009 | 1992 Nissan Maxima
     Grubhead
    Grubhead
